Old 07-24-2025, 05:36 PM   #1
Dorf55
Cool 55 ford steering column bezel
Good afternoon all !
I just relocated my column shifter from the steering column of my 55 Ford Fairlane to the floor.
I would like to find a steering wheel dash bezel that doesn't have the opening for the shifter tube.
Did Ford produce a floor shift on this model, so I can find such a bezel or is this just a pipe dream ?
I'm open to any suggestions.
Thanks
Dorf55
Dorf55 is offline   Reply With Quote
Old 07-25-2025, 08:31 AM   #2
Ford Freak
Default Re: 55 ford steering column bezel
Ford did not offer a floor shifter on your car. That goes for both standard & automatic transmissions. Which do you have? I had the same problem, as my car had the shifter (automatic) moved to the floor, & had no bezel on it when I got it. So, I mounted a small tachometer on the column, in front of the opening. Looks fine.
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 07-25-2025, 09:19 AM   #3
Dorf55
Thanks for the info, I have a standard shift and I already have a under dash mounted tachometer. its good to know were not the only ones with this issue.
Thanks
Old 07-25-2025, 10:31 AM   #4
40cpe
40cpe's Avatar
The previous owner of my car mounted a round light in the shifter tube location. This is not a good shot, but you can get the idea.
40cpe is offline   Reply With Quote
Old 07-26-2025, 02:27 AM   #5
KULTULZ
KULTULZ's Avatar
Arrow Re: 55 ford steering column bezel
I came across (either here or a website - CRS) where the owner modified the shift tube by removing the shift lever extension and re-installing.
Very clean appearance -
I have the photo(s) but they are on the wrong format. I will try to correct and post.
KULTULZ is offline   Reply With Quote
