Old 07-08-2025, 09:22 PM   #1
little howard
Default '32 Floor pans
Are the '32 floor pans the same for a 5-window and a 2-dor sedan ?
Thanks,
little howard is offline   Reply With Quote
Old 07-08-2025, 09:46 PM   #2
BoxCar Tom
BoxCar Tom's Avatar
Default Re: '32 Floor pans
The short answer is no. The 5W and the Roadster share the same floor which is essentially a flat floor. The Tudor floor by contrast has a flat section and a shaped deep stamped rear section. If you are building a hot rod and not concerned about authenticity than an aftermarket 5W/roadster floor could be fitted into a sedan body.
BoxCar Tom is offline   Reply With Quote
Old 07-08-2025, 09:59 PM   #3
John R
In addition to the good info provided by Tom, the front of the Tudor floor pan has two pieces of wood inserted as shown in the first attached photo. Instead, the front of the 5W floor has no wood but a section under the seat with two large depressions as shown in the second photo.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 07-09-2025, 02:12 PM   #4
alchemy
alchemy's Avatar
Howard you should have asked me in Des Moines, I could have lifted the seat and showed you.
alchemy is online now   Reply With Quote
Old 07-09-2025, 03:04 PM   #5
petehoovie
petehoovie's Avatar
Old 07-10-2025, 12:19 PM   #6
deuce_roadster
deuce_roadster's Avatar
Most of the different (American) 32 bodies had different floors. Recognizing this was a mistake, I think most (America) 33s use the same floor.
Old 07-11-2025, 03:22 PM   #7
Chris Haynes
Chris Haynes's Avatar
I have both the trunk and under seat floor pans from United Pacific New In Box. Pick them up in San Fernando Valley cheaper than from UP or Speedway.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
