Old 06-11-2025, 07:49 PM   #1
Alan O'Connell
Default !936 Ford Dash lights
I as looking at some posts about the dash lights being dim. I can see the fuel and oil gauge ok but not great. The speedometer is lit well enough but the temperature gauge and ammeter are difficult to see. I am using 6 candle power bulbs. Are there any brighter bulbs on the market?
Alan O'Connell is offline   Reply With Quote
Old 06-12-2025, 05:12 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: !936 Ford Dash lights
LEDs are much brighter.
Old 06-12-2025, 06:33 AM   #3
corvette8n
corvette8n's Avatar
Make sure you have a good ground to your dash and gauges.
corvette8n is online now   Reply With Quote
Old 06-12-2025, 08:50 AM   #4
ford38v8
ford38v8's Avatar
The bulbs don’t get dim over the years, but the plastic lense gets opaque. Find a good substitute for the lense and replace all of them for consistency.
Alan
Old 06-12-2025, 02:58 PM   #5
Alan O'Connell
Where would I get 6 v. led bulbs that fit in the original sockets?
Old 06-12-2025, 06:19 PM   #6
Model51
Model51's Avatar
Alan - There are lots of suppliers. Here are two that I have used. Logolites sells an LED 6 volt positive ground (“#63” LED Light Bulb) that drops right into the speedometer bulb clip and even has a round plastic cover in the same shape as the original
https://www.logolites.com/
https://www.classicandvintagebulbs.com/
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 06-13-2025, 07:28 PM   #7
325w
Hobby stores have sheet plastic you can make new colored lens for your dash lights.
325w is offline   Reply With Quote
Old 06-14-2025, 08:18 AM   #8
terry
I also increased the rectangular openings where the light goes through and plastic lens'
covers. Part of the pbm is that the light bulbs were not close enough to these openings
to give enough light to the guages. terry
terry is offline   Reply With Quote
Old 06-14-2025, 09:32 AM   #9
farmertom
farmertom's Avatar
research the industry # in owners manual or remove and look for #on orig bulb.ive bought dash bulbs,run/park,and headlight bulbs through amazon and ledlights.com for my '37 that fit in the orig.sockets.all 6volt. Tom. yep as model 51 said #63 sounds right couldn't remember if #53 or 63.
farmertom is offline   Reply With Quote
Old 06-14-2025, 09:48 AM   #10
Firechickenzz
Firechickenzz's Avatar
Ledlight.com is where I got mine for the dash tail lights and headlights. Now I can drive at night and actually see.
Firechickenzz is offline   Reply With Quote
