#1 |
Hey Y’all,
Got a question and maybe the only people that can answer this are those who like to keep a clean motor. I am running an engine with an aluminum intake and a leaky Holley carb. This combination it has caused gasoline to stain the manifold various shades of brown in places. I am not going to remove the manifold (but yes, I AM fixing that carb) but I do want to clean the brown stains off it. So, what product do you use to clean the brown gasoline stains off of your aluminum intake? Granted, I should have cleaned it sooner rather than let it buildup, but dealing with cancer makes one put off some things. What is your ‘it works every time’ solution? |
#2 |
I would try some oven cleaner. Carefully at first to make sure it doesn't darken the intake.
#3 |
Oven cleaner attacks aluminum and could turn the color black. I've used paint thinner, mineral spirts with good results.
Glenn
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
#4 |
See this posting for cleaning cast aluminum.
https://www.fordbarn.com/forum/showthread.php?t=348446 |
#5 |
Thanks fellas
#6 |
#7 |
Maybe soda blasting?
Making the simple complicated for over 30 years. |
#8 |
To clean aluminum, I always use "Alumiprep 33", or "Bonderite 33". It is 33% phosphoric acid, it CLEANS aluminum, the airplane guys use it.
Tom |
