Old 04-10-2025, 07:32 PM   #1
TomC750
TomC750's Avatar
Default Compression
Searched the forum and other places for acceptable compression numbers for my '41 Merc. Mine range between 70# and 80#. Any help?
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 04-10-2025, 08:02 PM   #2
tubman
tubman's Avatar
Default Re: Compression
It'll probably start and run OK with those numbers. Before I changed the engine in my '51, it was between 85 and 100 on all eight and it was OK to drive daily. You may be OK (for a while) if they're all about the same. Hopefully, a couple dosed of Marvel Mystery Oil and some driving will cause the situation to improve. Maybe a couple of shots of Sea Foam down the carb, as well.
Don't expect any "seat of the pants" thrills, though.
Old 04-10-2025, 08:43 PM   #3
TomC750
TomC750's Avatar
Tubman, thanks for the response. This vehicle does not smoke or burn oil. It wants to run strong intermittently, but has a tuneup problem I have not figured out. I do suspect a valve sticking occasionally when listening to the exhaust at idle. But there is something else. I am going to put an ignition analyzer on it tomorrow.
TomC750
1930 1 Ton White
Old 04-10-2025, 08:47 PM   #4
tubman
tubman's Avatar
Check for a weak condenser. Prepare to have to try one or more FLAPS condensers before you get a good one. I hear Vertex magneto condensers are very good, but they have to be special ordered.
Old 04-11-2025, 07:51 AM   #5
34fordy
34fordy's Avatar
I have no idea what a "flaps" condenser is and the Mallory is good but I would try a "TUBMAN TRASHCAN" for peace of mind!
34fordy is offline   Reply With Quote
Old 04-11-2025, 07:56 AM   #6
corvette8n
corvette8n's Avatar
My ‘41 is 60lbs on all 8 and it burns a quart every 40 miles, but I still drive it to car shows several times in the summer. Post some pictures of your Merc, I almost bought a two-tone 1941 Mercury w/jump seats but the paperwork was wonky so I passed.
Old 04-11-2025, 09:05 AM   #7
tubman
tubman's Avatar
Sorry, "H.A.M.B. term". "FLAPS" - Friendly local auto part store.
For the record, I am now out of condensers. Any future supply depends on whether I can talk my partner into making some more when I get back to Minnesota.
Old 04-11-2025, 10:07 AM   #8
mfirth
Stores like N A P A. Standing joke here is : Never Any Parts Available. The guys who work there are actually GR8 & get what they don't have next day.
mfirth is offline   Reply With Quote
Old 04-11-2025, 10:26 AM   #9
Drbrown
Drbrown's Avatar
Regarding concern about valves, attach a vacuum meter at you carb. If the indicator needle stumbles, jumps etc it could indicate a sticky or badly seated valve. This is not unusual for engines that don't get enough use. If so, next step might be to add some MMO .... a bit down the carb and a quart in the oil. At purchase my '47 had same symptom and the MMO cleared it up.
Drbrown is offline   Reply With Quote
Old 04-11-2025, 12:24 PM   #10
TomC750
TomC750's Avatar
I had a vacuum gauge on my engine, it fluttered a little bit, I did run some Seafoam through it, no change. It is not one valve that is a problem, it stumbles on all cylinders intermittently. I am going to do the MMO however.
TomC750
1930 1 Ton White
Old 04-11-2025, 12:27 PM   #11
TomC750
TomC750's Avatar
Charlie installed a new condenser, (NAPA) possible it is bad I suppose. I had my old ignition analyzer on it this morning, rather inconclusive. blurry trace, jumped around quite a bit.
TomC750
1930 1 Ton White
Old 04-11-2025, 12:30 PM   #12
TomC750
TomC750's Avatar
When it pulls, it pulls strong, even when missing intermittently.
TomC750
1930 1 Ton White
Old 04-11-2025, 12:40 PM   #13
tubman
tubman's Avatar
That's encouraging.
Old 05-21-2026, 12:29 PM   #14
AKCJ
Tubman
Dang!
I was just looking to see if I could order my very own trashcan.
Please keep us posted.
AKCJ is offline   Reply With Quote
Old 05-21-2026, 12:46 PM   #15
tubman
tubman's Avatar
Originally Posted by AKCJ View Post
Tubman
Dang!
Well you can, but they're now $100. My arthritis has gotten so much worse that I can't make them any more. I had several requests from the guys with after-market ignitions who don't mind paying the price for "the look", so I paid my partner to build 25 more for me. I think I have about 10 left.
And that, boys and girls, is how there came to be a $100 automotive condenser.
Old 05-21-2026, 12:59 PM   #16
Kube
Super Moderator
Kube's Avatar
I have had extremely good fortune with Hunts Magneto's. I get their 32mfd. condensers and put them inside a factory "body" to maintain the authentic appearnace.
Old 05-21-2026, 01:11 PM   #17
hueyhoolihan
my rebuilt '41's shows about 90psi on all cylinders and runs like a top with plenty of power...relatively speaking. and the original 6v electrical starting circuitry turns it over like a champ too!
hueyhoolihan is online now   Reply With Quote
Old 05-21-2026, 01:45 PM   #18
Kurt in NJ
Kurt in NJ's Avatar
At the auto shop I worked at every compression tester had a different reading and it was a 30 pound range difference including high dollar name brand tool companies.
the lowest readings were from ones with long rubber hoses (the rubber hose expands with pressure and the length in
essence lowering the compression ratio.
My favorite one for gasoline engine has a steel reinforced hose similar to hydraulic hoses.
The diesel tester has wire rods inside the hose to reduce its volume
Another factor is carbon that gets dislodged when the spark plug is removed, ideally the plug’s are loosened a turn and the engine is started and rpm’s sharply increased a couple times to flush and dislodged carbon out the exhaust so it can’t give you a erroneous result if it gets caught under a valve during the compression test.
Old 05-22-2026, 06:21 AM   #19
Terry,OH
Terry,OH's Avatar
solid wire plug wires, not resistance or radio suppression and the plugs also copper core is OK. plugs at about 0.025"
