Model at stuck Bendix
Been having so many issues with my 26 T roadster pickup! Went to start the other day and electric starter locked up. Tried to crank and that was locked up too. Car won’t even roll out of the garage. I read this could be due to a stuck bendix on the electric starter. I removed the Bendix housing and there is a loose piece that seems like it is broken, but I’m not sure. Still can’t get the crank loose either! Photo attached. The ring in the center is loose and spins freely, also wobbling.
Thank you!
