#1 |
Double Venturi Bowl half before and after cleaning up! Lots of heat/windex and cold water.Bead blasting.
www.whidbeymodelaclub.com |
#2 |
Gary, where will you find a new venturi for that carb?
#3 |
I have a few and I did that one for someone else who has one. They were available thru the vendors but supply is out.!
#4 |
Does a single venturi fit the housing?
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
#5 |
yes they will,read where they were changed in late 1928 because mechanics were breaking them when taking apart so changed to single venturi. never tried to run a DV with single not sure on the operation.
#6 |
#7 |
Originally jets were numbered replacements generally aren't. Flow testing is the only way to ensure accuracy of jets; various articles elsewhere on Fordbarn about that topic!
If going by numbering Idle usually 10 or 11, Main19.5 or 20, Comp 18 or 19, Cap 19, 20, or21 jets are interchangeable on SV and DVs and Zeniths I and 2 and Holleys lookalikes , |
#8 |
#9 |
I read somewhere that the double venturi was dropped because of a patent dispute.
#10 | |
https://casetext.com/case/stromberg-...nith-detroit-2
Jim Cannon Former MAFCA Technical Director ![]() "Have a Model A day!" |
#11 |
Good stuff. Thanks guys. I have a KTK carburettor which is DV. I'd like to get it going - just coz. IMO a Japanese carburettor on the Model A would raise a few eyebrows.
#12 |
Holley / Zenith Double Venturi.... found another core to assemble and run. Here again someone removed the locator / indexing pin. The pin is another item I need to reproduce as many were ground off or tapped out so that a later venturi could be used.
Back when my dad and I used to rebuild carburetors as a service, we would only get maybe 1 or 2 a year. I wonder how many of these dual venturi upper and lower castings are still out there? |
#13 | |
Like a "Mochi" which appeared on the Avatar for one show. Joe K
Shudda kept the horse. |
#14 | |
I don't know why that many mechanics would already be working on them in the first 6 months that the car was being built. What I have read about the DV is that Ford was faced with a potential lawsuit from Stromberg, that is a well documented reason for changing. I also believe that there would've been Ford service bulletins about this with Ford advising their dealers to replace or be mindful when working on the DV carburetors. I'm sure at the Benson library there's an Engineering Information sheet that explains this, too bad we can't get back in there.... |
#15 | |
It just all depends on whose collection is being sold off this year...
Member, MARC Current owner, 1928 RHD Australian-built Phaeton CA4752 "Felicity" Former owner, 1931 Victoria, 1929 Phaeton, 1929 Fordor |
#16 |
#17 | |
I think like a lot of old timers they always have some bit of folklore / wives tales mixed in with their explanations. I can't believe that mechanics were breaking that many of them so early on, that's just unbelievable and then to not have any mention of it in service bulletins.... Thanks for the reference though, I'll ask Mr. Biggar about it. |
#18 | |
