#1 |
Hey All,
What parts am I going to need to mount a 36 Ford Truck transmission to a Mercury EAC Engine? Are the truck transmissions any different than the passenger cars that year? Thanks, |
#2 |
You'll need the 3" '48-'52 truck or '49-'50 Mercury 1/2 bell housing, along with necessary clutch and flywheel mods, changes or additions.
The 1/2 ton truck 3-speeds are the same as pass car iirc. The heavy truck transmissions are much different, but will still need the same conversion parts. |
#3 |
What clutch setup are folks recommending and running?
This will be a fairly stock engine build. It will have a Max 1 cam and maybe dual carbs with headers so nothing gnarly about it. Just looking for a comfortable cruiser. |
#4 |
Historically, '49 or '50 Mercury clutches were used. These seem to be unavailable at the present time. I have heard that CenterForce or even Speedway Motors have replacements.
#5 |
I have heard bad things about Speedway stuff. Centerforce sounds good.
#6 |
Home | Kentucky Clutch | Car, Tractor & Truck Clutch Repair & Kits
Making the simple complicated for over 30 years. |
