#1 |
I don't like the angle of the throttle rod situation I'm looking at in my '51 with 2x2 Offy and 97's. I did this exact swap before, but it was like 15 years ago, and I just don't remember this rod angled like this. I'm thinking of heating and bending the end of the cross shaft about 90 degrees up so it would be a straighter pull on the carb, but I don't know, any thoughts OR does anyone with a shoebox running 2x2 care to show a pic of their carb linkage. Thanks guys.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
#2 |
Anyone,..thoughts or picture most welcome. Thanks
#3 |
I don't see any issue with that angle - it isn't much.
#4 |
Agree with B&S. I also don't think that rod is strong enough to handle a bend. I think you'll find it will flex at the bend instead of pulling like you'd like it to. There is decent tension on the spring by design so it closes when you let off the pedal.
#5 |
Looks good to me.
#6 |
#7 |
THANK YOU GUYS for weighing in on this, I just needed some affirmation from some knowledgeable folks,....and you all are. I will carry on.
