Old 03-08-2025, 08:42 PM   #1
Ken Arms
Ken Arms's Avatar
Default 34 horn and light switch
So, can someone tell me the correct orientation of the light switch when all lights are off. Vertical or horizontal ? Thankyou Ken
Ken Arms is offline   Reply With Quote
Old 03-08-2025, 09:08 PM   #2
rockfla
rockfla's Avatar
Default Re: 34 horn and light switch
6 &12. Or Verticle
Old 03-08-2025, 09:36 PM   #3
petehoovie
petehoovie's Avatar
OFF
Old 03-09-2025, 12:53 AM   #4
koates
Ken, do you not have a 34 Ford drivers handbook which shows all this kind of information ? One came with every new car. Regards, Kevin.
koates is offline   Reply With Quote
Old 03-09-2025, 10:26 AM   #5
Ken Arms
Ken Arms's Avatar
Thanks to all. I had the horn rod out to clean intermittent horn issue and turns out you can assemble it either way.
Old 03-12-2025, 12:35 PM   #6
Ken Arms
Ken Arms's Avatar
By the way, if your horn intermittently fails to honk or not at all and your sure the horn and wiring is ok then you may want to clean the contact at the button on your wheel. That was the fix for mine. There are four tabs at the back side of the light/horn button assembly that have to be bent straight to get in there for cleaning. Ken
