Old 03-07-2025, 10:41 AM   #1
Bullerman
Default Throwout bearing
Who makes a good throwout bearing for a 50 Ford with Flathead V8 239 cu in.
I got one from one of the parts houses and I didn't think too much of it.
The transmission is having to come out again and I am thinking about putting in a new one
Bullerman is offline   Reply With Quote
Old 03-07-2025, 11:07 AM   #2
cas3
Default Re: Throwout bearing
VanPelts Sales.com
cas3 is online now   Reply With Quote
Old 03-07-2025, 11:36 AM   #3
tubman
tubman's Avatar
Just what I was going to suggest myself. I seem to remember, there was a discussion about this a few years back and Mac stepped in to fully explain the matter. A "Search" may reveal something.
tubman is online now   Reply With Quote
Old 03-07-2025, 04:12 PM   #4
Shoebox
Shoebox's Avatar
I second Mac VanPelt as a source. I also got a nice NOS one off E pay.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 03-07-2025, 04:39 PM   #5
Kube
Super Moderator
Kube's Avatar
I prefer NOS or NORS. Way too many modern bearings are not of great quality.
Old 03-07-2025, 09:35 PM   #6
1948F-1Pickup
1948F-1Pickup's Avatar
The originals were Aetna. Here’s one for my ‘48 truck. I checked when I was at NTN and Aetna still was making them, I believe, but they got acquired by an equity firm in 2016. Who knows what the story is these days.
1948F-1Pickup is offline   Reply With Quote
Old 03-07-2025, 09:39 PM   #7
ford38v8
ford38v8's Avatar
I'll never forget nor forgive myself for the time, as a 17 year old kid, I did a great job in rebuilding my '49 Ford transmission, getting it reinstalled, all buttoned up, and tried to go for a joy ride. I'd gotten the throwout bearing on backwards. My mother admonished me for my blue language that evening at the supper table. Mt father, who never cussed at all, did not raise his eyes from his dinner plate.
Alan
Old 03-07-2025, 10:00 PM   #8
petehoovie
petehoovie's Avatar
Old 03-07-2025, 11:15 PM   #9
cas3
Pete, your hogging the nos ones aren't you! you devil you!
Old 03-08-2025, 07:17 AM   #10
Mac VP
Mac VP's Avatar
The 49 and up passenger car bearing itself is smaller than the 78-7580 bearing pictured above. This smaller bearing has the 8A-7580 Ford part number. We stock this bearing and it’s a USA made part. The bigger problem is that many customers need the bearing AND the carrier hub as well. The 49-51 hub has not been reproduced in recent years. You can find them occasionally via auction sites etc but not through the normal vendor channels. We’ve got a supply of the spring that is riveted to the carrier hub (but not the rivets). Hopefully some vendor or manufacturer will be able to step up and produce this item again…..in the meantime, this is the current situation.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 03-08-2025, 10:26 AM   #11
Drbrown
Drbrown's Avatar
Order from the manufacturer when possible. My experience: Rock Auto sold me a wheel bearing. It had the name "Timken" on it ..... Timken now located in Canada. I Checked with Timken and found I could have bought it directly at half of Rock Auto's price. Complained to Rock Auto about their 100% mark-up and of course they just sort of said that's the cost of business.
Drbrown is offline   Reply With Quote
Old 03-08-2025, 11:23 AM   #12
V8 Bob
V8 Bob's Avatar
A couple friends and I bought early '50s NOS Ford throw-out bearings many years ago, and found the original grease had deteriorated so badly the bearings would need to be disassembled, cleaned, greased and re-assembled to be useful, something they are not designed to do.
New quality bearings were purchased from our local clutch rebuilder and assembled onto the OE carriers.
Sometimes , NOS is not the best option.
V8 Bob is offline   Reply With Quote
Old 03-08-2025, 11:35 AM   #13
V8 Bob
V8 Bob's Avatar
Delete
Old 03-09-2025, 04:15 PM   #14
Tim Ayers
I was thinking the same. Think about it. That's close to 75 years that grease has been sitting around. VanPelt or Third Gen would be great places to start.
Old 03-09-2025, 09:40 PM   #15
Bullerman
Will call Van Pelt Monday. Thanks.
Old 03-09-2025, 11:12 PM   #16
tubman
tubman's Avatar
You shouldn't be having all of these problems. With all the work and parts swapping, I am starting to wonder if there aren't some alignment issues somewhere in there.
About fifty years ago, I had a '50 Buick special with a stick shift. It was a real clean car, but cheap because the transmission made a terrible noise. I pulled it apart (a bigger job than I had first imagined because of the torque-tube driveline) and replaced some bearings. It was OK for about a year until it started making the same transmission noises. I kept driving it until the transmission failed completely. Later, I was able to source a rebuilt transmission from Sears. I figured that my jury-rigged repair had probably not been good enough, but a "professional rebuild" would solve my problems. It did; for about a year, when I started getting the same noises again. This time, I took it to see an older friend who was the senior mechanic at the local Chevy dealership. After listening to it and my tale of woe, he said that I probably had an alignment problem with the transmission and bellhousing etc. and that it would take time and money to find and fix it. I sold the car the next week, as I couldn't take dealing with the torque-tube a third time.
The next time you have it apart, get under there with a dial indicator and a steel rule.
Old 03-10-2025, 07:38 AM   #17
KiWinUS
KiWinUS's Avatar
It is not too difficult to clean out the old grease and fill with fresh grease without taking bearings apart. We learned this in the early years of my apprenticeship. Just the same as a used throw out bearing.jeepers that was 55 ish years ago.
Old 03-10-2025, 07:54 AM   #18
Tim Ayers
Tony,
Interesting. Could you share some Cliff Notes on how to do it? I'd be interested in giving it a try.
Thanks,
Tim
Old 03-10-2025, 12:37 PM   #19
Kube
Super Moderator
Kube's Avatar
I have installed more clutch assemblies than I am able to recall. I have ALWAYS used NOS or NORS bearings. Not once was there an issue.
Old 03-10-2025, 12:54 PM   #20
Tim Ayers
Good to know.
