Old 02-26-2025, 01:24 PM   #1
jetmek
Default Truck oil pan ?
Ran across this pan with removable lower flywheel section but noted it has no oil breather. Cant figure out its intended use.., i know 32-35 never had a removable rear section or oil filter return. Ideas?
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 02-26-2025, 09:01 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: Truck oil pan ?
The 1948 and earlier Ford flathead V-8 oil pan with the removable lower section was used on commercial vehicle's.
The idea being a truck or bus would wear out a clutch a lot faster than a car. So making it easy to remove that rear lower section of the pan made a clutch and flywheel removal a lot easier than pulling the entire oil pan. Some of the larger trucks and buses were an open drive type transmission so the tranny removal was easier as well. No toque tube rear or an engine to pull to get the transmission out.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 02-26-2025, 09:08 PM   #3
petehoovie
petehoovie's Avatar
Old 02-26-2025, 10:58 PM   #4
cas3
Ronnieroadster, do you have any thoughts about the lack of the normal breather exit?
I've never seen a post 35 pan without the breather
Old 02-27-2025, 03:18 PM   #5
Zeke3
Zeke3's Avatar
Did military use a PCV system?
Zeke3 is online now   Reply With Quote
Old 02-27-2025, 05:07 PM   #6
alchemy
alchemy's Avatar
Looks like the main pan stamping and the doubler brace had room for the breather. The worker must have sneezed when that pan went down the assembly line.
alchemy is offline   Reply With Quote
Old 02-27-2025, 09:51 PM   #7
Lawson Cox
Lawson Cox's Avatar
P-iss poor job of sand blastin the pan.
Old 02-28-2025, 09:58 AM   #8
V8 Bob
V8 Bob's Avatar
Yes, and my guess is this is a military pan.
V8 Bob is offline   Reply With Quote
Old 02-28-2025, 01:38 PM   #9
rotorwrench
rotorwrench's Avatar
Most trapdoor pans were for the big 4-speed clutch. V8s were used in the universal carriers in both 221 and 239 types and they had to have a PCV and oil coolers due to placement in the middle of the carriage. Some big trucks also had PCV in Canada. I'm not sure about US manufacture.
Old 02-28-2025, 09:11 PM   #10
jetmek
Delete
Old 02-28-2025, 09:13 PM   #11
jetmek
Your more than welcome to come here and stand out in the snowbank with a blaster to bring it up to your standards
Old 02-28-2025, 11:45 PM   #12
big deuce
big deuce's Avatar
Maybe he's not done cleaning it up... the thread wasn't titled " how's my sandblasting job?" It's a dam sight cleaner than mine will ever be.
big deuce is offline   Reply With Quote
Old 03-01-2025, 08:20 AM   #13
jetmek
Thanks. Its prob is a military truck part
