Old 02-03-2025, 06:59 PM   #1
Bluehills 42 2ton
Default 2 ton truck rims
Hello everyone I’m new to the forum and I’m currently doing a frame of restoration on a 1942 2 ton truck. I’m wondering if anyone knows if there are any rims available to purchase I currently have the split ring rims on the truck two of which were flat and after cutting one tire off and finding the rim very badly rusted I was hoping to find a couple of replacements any help is greatly appreciated thanks
Bluehills 42 2ton is offline   Reply With Quote
Old 02-03-2025, 07:33 PM   #2
Reds34
Default Re: 2 ton truck rims
Truckdog (Stu) is the man when it comes to truck rims.
Where in Massachusetts are you? I may have some rims for your truck at my parents' house in CT.
Red
Reds34 is offline   Reply With Quote
Old 02-03-2025, 07:57 PM   #3
Bluehills 42 2ton
Duxbury
Old 02-03-2025, 07:57 PM   #4
truckdog62563
truckdog62563's Avatar
Thanks for the nice words, but I fear I’m not much help to the new member. I don’t have any available. If you, or anyone, has available wheels and needs help in identifying them I can try to help. Stu
Edit - I guess I should suggest that Blue look at the inner/concave flat surfaces of his center discs and post their Budd numbers, assuming they are Budd products. Post the numbers and I should be able to give their particulars to compare to any replacements that are found. Stu
Stu McMillan
Marmon-Herringtons
truckdog62563 is offline   Reply With Quote
Old 02-04-2025, 02:35 PM   #5
ActionYobbo
ActionYobbo's Avatar
I have 6 wheels of a 39 1.5 ton in AR
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 02-04-2025, 05:08 PM   #6
fordyford
fordyford's Avatar
I have several good 20" truck wheels that fit your needs in dry Colorado.
Keith
fordyford is offline   Reply With Quote
Old 02-04-2025, 07:09 PM   #7
Newc
Newc's Avatar
Split Rims ? or just locking rings ? Big difference. The locking ring types are ok. Lots of posts on this subject here. Newc
