#1 |
Any of you guys have a tried and true method of removing these vacuum set screw plus from intakes? I obviously tried a screw driver to NO avail and it finally skipped SO I stopped before I mess anything up any further!!!
Thanks!!! |
#2 |
I had the same problem with cast iron valve covers. I ended up carefully drilling it out incrementally increasing drill bit diameter until I was afraid of hitting the threads or the bottom seat in the valve cover. Then I used a pick to pry the remaining brass bits out (along with some choice words which are inappropriate to mention here). Obviously I had the valve cover on the bench and not on the engine.
I think the issue of dissimilar metals is the culprit. Looks like you have a harder challenge with soft aluminum.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
#3 | |
The current plan is to remove the intake so I can get a better angle on it and not contaminate anything else and do just as you have described…..I can’t think of any other way!!! |
#4 |
If you can get a straight shot at it from the inside, it would be easier to drill it out and the drill might catch and run it right out. Or is this what you meant by a "better angle"?
#5 |
Hand held impact driver? The type you hit with a hammer?
#6 |
#7 |
Heat the area around the plug with a propane torch, DON'T have to get it very hot, lots of expansion to aluminum and pot metals.
#8 |
A combination of Mart and Terry with a shot or two of PB blaster when hot normaly works. The aluminium will exspand much farther and faster then the steel plug. This should break the bond and also alow the oil to get down in the threads. Tim
#9 |
dont the intake have a taper for the fitting? you could end up messing that up by drilling it out
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
#10 |
Just did one of these two weeks ago. Used my mini-ductor and a shot of free-all and it came right out
#11 |
#12 |
Tim, I'm always looking for a better tool. What heat tool do you have? Tim
#13 | |
I got the Bolt Buster brand tool. Mainly because it's made in the USA. Since I got it, the torches only come out for cutting. It's been a life saver for our daily drivers and old Fords. https://boltbusterinc.com |
#14 |
#15 |
#16 |
Whaa Laaa
