Old 01-30-2025, 02:58 PM   #1
Masot
Default engine ventilation
Hi!
This is my engine ventilation system.
I made a small clean air filter.
Invert the system.
Now it goes directly under the crankcase, goes up and comes out through the back of the clean air vent.
It works very well, now I don't have any oil leaks.
Masot is offline   Reply With Quote
Old 02-01-2025, 10:30 AM   #2
19Fordy
19Fordy's Avatar
Default Re: engine ventilation
Perhaps I am missing something as I don't understand how your ventilation works.
Wouldn't the OEM system work the same way?
Old 02-01-2025, 12:02 PM   #3
signsup
I know just enough about air filters to be rated "challenged", but on most vintage military vehicles, the air filter is mounted away from the engine and uses a series of hoses and cross over tubes to connect to an air horn on the carberator. This not allows for snorkle and fording systems to operate, but provides a source of oil bath fresh air to the carb that is away from engine heat. Just FYI. Every vintage civilian car I've ever worked on has it mounted directly over the carb, so go figure. And, of course, the Model T had absolutely nothing to filter air unless it was after market.
signsup is offline   Reply With Quote
Old 02-01-2025, 12:30 PM   #4
tubman
tubman's Avatar
Engine ventilation is not the same as air filtration for the carburetor.
I sorta glossed over this at first, but after reading the last couple of posts, I took a closer look. From what I can see (it's not exactly clear from the pictures), it appears the O/P has reversed the flow of air through the engine so it functions like the earlier engines rather than the improved 8BA method. If this is the case, I am surprised it works as well as he says. It is contrary to the basic design of the 8BA engine. I sure wouldn't recommend it over a properly installed PCV system (or the original system, for that matter).
Old 02-01-2025, 01:53 PM   #5
40cpe
40cpe's Avatar
Maybe the OP can clarify. There are 8BA heads/intake on an engine with what appears to be a front mounted distributor. Is this an earlier block?
40cpe is offline   Reply With Quote
Old 02-01-2025, 01:58 PM   #6
tubman
tubman's Avatar
Look at his last picture. It doesn't appear to be an extended block; looks like an 8BA to me. Also, check out the internal vent tube in picture # 4.
Old 02-01-2025, 02:24 PM   #7
signsup
Never mind. Is this what I would call crankcase ventilation?
Old 02-01-2025, 04:33 PM   #8
ford38v8
ford38v8's Avatar
I don’t think you could call it a crankcase ventilation system, as both vent tubes emanate from the valve chamber. I believe it could be more effective if you run a tube from the rear vent directly into the carb air cleaner.
Alan
Old 02-01-2025, 05:50 PM   #9
signsup
The WWII jeeps did not have a pcv system per se, just draft tubes coming off the side of the block. The next series of Willys jeeps had a PCV valve that ran between a metal cross over tube that provided fresh air to the carb from the air filter and was connected to the oil filler tube. This PCV valve was controlled by a cable that fed into the tub dash. And, when in the closed position would use the pressure from the engine block to help keep water out of the seals and gaskets. Then opened up again when not under water. If the driver left the system closed, it created problems so the military went to wiring up the valve and mking the driver undo the wire prior to fording. Now you know more than you wanted.
Old 02-01-2025, 09:50 PM   #10
Newc
Newc's Avatar
A Neg pressure in the block is the idea ? right? No more leaks. Newc
Old 02-02-2025, 04:22 AM   #11
3W Hank
I plan to use a Stelling breather on the oilpan on mt 41 Merc block but it could be a tube up aswell. That must reduce pressuare.
3W Hank is offline   Reply With Quote
Old 02-02-2025, 06:15 AM   #12
tubman
tubman's Avatar
It's becoming apparent to me that there are a lot of folks out there that don't understand the ventilation systems used on flathead Fords.
Old 02-02-2025, 07:32 AM   #13
V8 Bob
V8 Bob's Avatar
Bingo!
V8 Bob is offline   Reply With Quote
Old 02-02-2025, 09:58 AM   #14
3W Hank
Tubman,
On the 59 blocks its no really a crankcase ventilation, it's a hole in oilpan and then its the oilfiller cap.
The idea to use a vintage breather to oilpan was some pictures I seen people used it in the past.
I had a topics on it before here but was told only it leaks - no good.
I guess the idea was get a pressuare out of the case.
I know the 8AB had a updated system.
On my stocker 426 Hemi I has K&N breathers on the valvecovers.
I made parts( impeller ) to a dry sump system they use in Nascar and that help crankcase build up vacum and that gain HP, but thats another story.
Look at the air oil separator.
Little overcourse for a FH I guess..
https://www.autoverdi.com/pump-design
Old 02-02-2025, 10:33 AM   #15
V8 Bob
V8 Bob's Avatar
3WHank,
The 59A blocks utilize the same crankcase ventilation that started in '35. The later 8BA system was an upgrade because of engine design changes.
Below are pictures of early and late crankcase ventilation that have been posted many times.
Air has to move to create proper crankcase ventilation, not just simply adding vents.
Installing a pcv ensures air flow both while the vehicle is moving or stationary.
File Type: jpg '35-'48 flathead ventilation.jpg #2.jpg (12.6 KB, 33 views)
Old 02-02-2025, 11:13 AM   #16
glennpm
glennpm's Avatar
http://www.reds-headers.com/html/red...e_talk_19.html
Crankcase Ventilation
Nov/Dec 2003
I still get questions on this. Here you go again.
Our 32-34 Ford V-8's had crankcases that were vented only. In 1935-53 they were ventilated. What is the difference? Why did Ford change that? What can we do with the 32-34 engines to improve their lack of ventilation?
Crankcases are vented because of the pressure build up in them due to blow by and heat. An engine that is not vented may distort or burst the oil pan, or perhaps other parts, enough to ruin them. At best, it would cause lots of oil to leak past gaskets and seals.
The problem with a crankcase that is vented only is that the combustion products that get past the rings include water and acid vapors. These condense into the oil and onto metal surfaces in the engine. The vented only crankcases have no way to purge these corrosive products from the oil. Bearing materials and aluminum pistons are easily damaged by these chemicals.
The engine block and pan were revised in 1935 to provide ventilation, including a road draft tube. It was built into the right front of the pan. This connected to a passage in the block that opened to the top front of the valve chamber. The flow of air past the slot in the rear of this pan projection, caused by the speed of the vehicle, creates a slight vacuum. This mild vacuum creates a flow of air through the filtered oil fill cap, down into the crankcase, then up through the valley and out the road draft tube. When the engine and oil are at operating temperature, this air flow purges the water and acid vapors, as well as some oil vapors, from the inside of the engine.
On 1949-53 engines, the arrangement was a bit different, but the result is similar. The road draft passage to the front of the valley is external with an internal passage pulling vapors out of the crankcase. The breather allows filtered air in at the front of the valley to complete the cycle. The late system (1949-53) is probably a little better because it separates the vapors from fluid oil better. This gives less oil drippage from the road draft tube.
To add some ventilation to the vented 32-34, consider a hidden PCV valve. It can be plumbed into the bottom front of the intake manifold, drawing from the front of the tappet chamber. This is not as good as the later setups, but burning these vapors is better than breathing them.
If you are using 1949 and later engines in your earlier cars, consider using all of the late components. This will preserve the factory ventilation scheme. If you use a later intake manifold on an early engine, or vice versa, crankcase ventilation does not work correctly. You
could at least partially remedy this with a PCV system.
To recap, crankcase venting keeps your pan from blowing up. Crankcase ventilation keeps your oil cleaner and helps your engine last longer.
This illustration shows a 1939-48 engine with the road draft tube and passage in the pan, as well as the oil fill/vent tube.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 02-02-2025, 12:16 PM   #17
3W Hank
I has the breather from Stelling I seen was used in the past on the oilpan side, for now most a cool idea.
The oilpan is a truck oil pan splitted rear but the open hole in the pan in front.
So either stay std or otherwise how to out the PVC valve.
( Multi x4 carb intake )
