Old 01-27-2025, 04:35 PM   #1
Kelly Burns
Kelly Burns's Avatar
Default 47 outside door handle won’t open the door, now.
I bought my ‘47 in October, and the other day, for some reason, I decided to look the driver’s side door. It was only hard to turn the key, but not enough to “force it”, if that makes sense. It was enough that I thought to try to unlock it, and I can’t, and I’ve use more force than it too to lock it. I’ve not leaned really hard, I didn’t want to break the key off or something else. But not the door is locked, I can still open it from the inside without any problem. I called the guy I bought it from, his dad had owned it since ‘86, and he said he did think the door had ever been locked, while he had it.
What advice do you have for me to get the door unlocked? I’ve not tried spraying silicon spray or WD-40 in the lock yet, which my first thought was it’s dirty inside?
Thanks for your help!
Kelly Burns
Kelly Burns is offline   Reply With Quote
Old 01-27-2025, 04:48 PM   #2
Doublepumper
Doublepumper's Avatar
Default Re: 47 outside door handle won’t open the door, now.
Most likely one or more of the pins inside the lock are not retracting completely under spring pressure due to hardened lube. I'd spray it with WD, working the key in and out of the lock. That should work the lock pins enough to get them free. Good luck!
Ever stop to think and forget to start again?
Doublepumper is offline   Reply With Quote
Old 01-27-2025, 05:10 PM   #3
Ggmac
Have you tried unlocking it from the inside ? Then retry the key .
Ggmac is offline   Reply With Quote
Old 01-27-2025, 07:31 PM   #4
TJ
TJ's Avatar
It sounds like the spring in the remote mechanism that is behind the handle is broke and has jammed the mechanism. You need to pull the door panel to check that spring.
Old 01-27-2025, 07:49 PM   #5
paul2748
paul2748's Avatar
Definitely try some WD 40 or similar. Had the same problem with my 2001 ranger WD 40 took care of it.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-29-2025, 12:17 AM   #6
Kelly Burns
Thanks for the advice guys!
I sprayed WD-40 in the lock tonight and worked the keys in and out, I figured I would do the same tomorrow night and see what happens.
Kelly Burns
Old 01-29-2025, 12:36 AM   #7
tubman
tubman's Avatar
Locks are funny things; they can become gummed up, which is why they make special lock lubricant with graphite. On the chance that WD-40 would accumulate dust and dirt over time, I would use brake cleaner for the initial cleaning, and then the specialized lock lubricant if it freed up.
Maybe "32Phil" will see this and add his expertise.
Old 01-29-2025, 09:28 AM   #8
325w
Might take the lock out of the door and soak for a while..could be stuck in the latch part of the lock
325w is offline   Reply With Quote
Old 01-30-2025, 12:11 PM   #9
Kelly Burns
Its still not budging! So last night after driving it to dinner, I sprayed brake clean in the lock a couple of times. Tonight, I'll shoot more WD-40.
"Maybe "32Phil" will see this and add his expertise" I hope so!?
Kelly Burns
Old 01-30-2025, 12:12 PM   #10
Kelly Burns
Can the lock just be simply taken out?
Kelly Burns
Old 01-30-2025, 12:17 PM   #11
tubman
tubman's Avatar
They can be a bit of a problem. Don't just jump into it without doing some research. See this thread : https://www.fordbarn.com/forum/showthread.php?t=345776. The good stuff starts about post 12.
Old 01-30-2025, 01:56 PM   #12
kurt v
Stay away from wd40 it is a water displacement and not a lubricate, it will only gum stuff up over time.
kurt v is offline   Reply With Quote
Old 01-30-2025, 02:13 PM   #13
tubman
tubman's Avatar
He is correct; and, from the name, it took them 40 tries to get it right. If you need a penetrant, use PB Blaster, Sea Foam spray, or maybe even good old Liquid Wrench. For just cleaning things, Brake cleaner is probably better than anything.
Old 01-31-2025, 12:11 PM   #14
JayChicago
JayChicago's Avatar
I used WD40 on new hinges in my house. Couple years later when squeaks developed, the hinge pins required beating to get them out. The WD40 had turned to a sticky gum. Cleaned the pins with solvent, lubed with liquid graphite.
JayChicago is offline   Reply With Quote
Old 01-31-2025, 01:01 PM   #15
cas3
And, don't ever get WD 40 anywhere near anything you are planning to paint. Its nearly impossible to get cleaned off and will make "fish eyes" in the paint
Old 02-01-2025, 11:07 AM   #16
Drbrown
Drbrown's Avatar
I agree with Tubman. What most any locksmith would say is WD and the like might be okay to loosen-up a lock cylinder but afterwards take it apart and use dry graphite to lube the cylinder.
Drbrown is offline   Reply With Quote
