Old 01-22-2025, 08:02 AM   #1
oldgas
Default Fuel
My 1956 Ford Convertible that has a fuel problem.
Is there information on a blocked fuel pick-up tube on how to repair?
Thank you for your time.
Old Gas
oldgas is offline   Reply With Quote
Old 01-22-2025, 09:02 AM   #2
GLAmes
GLAmes's Avatar
Default Re: Fuel
Pick up tube? Isn't the fuel line fitting on the bottom edge of the tank like a '54?
'54 Skyliner. As close to original as I could restore it to.
GLAmes is offline   Reply With Quote
Old 01-22-2025, 09:57 PM   #3
miker98038
miker98038's Avatar
Default Re: Fuel
First, blow back with low pressure compressed air. But also maybe this
https://www.ebay.com/itm/171963985993
miker98038 is offline   Reply With Quote
Old 01-23-2025, 11:10 PM   #4
dmsfrr
dmsfrr's Avatar
Default Re: Fuel
I'd loosen the gas cap first, just in case.
dmsfrr is offline   Reply With Quote
Old 01-24-2025, 02:19 PM   #5
rotorwrench
rotorwrench's Avatar
Default Re: Fuel
I use a length of speedometer cable core to push into the tank outlet bung. My Mercury cars have an internal tube that runs along the bottom and angle up then straight back to act as a stand pipe just above the bottom. Pulling the tanks is a PITA but sometimes it's the only way to get the crud out of the bottom. It can build up pretty thick over decades of setting. My Mercs have drain plugs in the tank but not all do.
I squirt MEK in and then start poking. Fuel tank work is not fun.
