Old 01-19-2025, 07:16 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default KR Wilson engine stand
I am trying to remove the engine mount from the stand. The wing nut came off easily. Now I can't figure out how to remove the rest.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 01-19-2025, 10:11 PM   #2
desertrust
Default Re: KR Wilson engine stand
Notch plate has keyway all way thru. Pull it off. Shaft has key in its keyway but is short, not to end of shaft.
desertrust is offline   Reply With Quote
Old 01-19-2025, 11:21 PM   #3
GB SISSON
GB SISSON's Avatar
So, that 'notch plate' has those big notches where a dog drops in at each of the normal repair positions for our flatheads? No wonder you guys all like them so much. The Harbor Fright ones provide absolutely no 'pride of ownership' (or feeling of safety).
Old 01-20-2025, 10:56 AM   #4
KiWinUS
KiWinUS's Avatar
Ya get what you pay for. The antique KRW stands are expensive but well worth it.
Old 01-20-2025, 11:45 AM   #5
Tim Ayers
I just wish they didn't take up so much real estate in the garage. They need a dedicated space
Old 01-21-2025, 09:29 AM   #6
oldandtired
Chris Haynes...I like your quote on your post that says, "Speed costs money. How fast do you want to go?" It ranks up there with, "Never enough time to do it right; always enough time to do it over."
oldandtired is offline   Reply With Quote
Old 01-21-2025, 12:43 PM   #7
Ronnieroadster
Ronnieroadster's Avatar
To get mine apart at times I wedge the end of a big flat blade screw driver between the end notched plate and the main body.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 01-21-2025, 07:45 PM   #8
Flathead Fever
Flathead Fever's Avatar
That rear plate with the notches should just slide off. Then the shaft and engine mount should slide out the front. It might take a couple of screwdrivers to gently get plate to slide off its keyway. I have three of those KRW engine mounts, none of them came with their bases. I had to make the one base. Another one I have bolted to the floor.
Flathead Fever is offline   Reply With Quote
Old 01-22-2025, 02:18 PM   #9
Randall
Randall's Avatar
Here’s a stand that uses KRW fixtures it’s a JG Devin
Randall is offline   Reply With Quote
Old 01-23-2025, 12:56 PM   #10
Dan McEachern
Just FYI, I will have several NOS KRW engine stand heads for sale at the Turlock, Ca Swap meet Jan 25th-26th. Also an early and a late tool tray.
1 V-8 60 head, one SV-40 Fat Head and a few of the Lincoln V-12 adapter plates for adapting the V-8 head to hold the V12. Plus one universal head with the two arms for holding 3rd members etc. I'm in the building across from the snack bar in the corner by the roll up door. Will have other KRW tools as well. Come on by and take a look.
Dan McEachern is offline   Reply With Quote
