Old 01-06-2025, 04:31 PM   #1
oswego37
Default 37 transmission question
I'm almost ready to remove the transmission from my 37 club cab. does it go down and out or up and out? it looks tight either way. And i would like not to remove the rear mount if that's at all possible. any thoughts are appreciated. Thanks, Ernie
oswego37 is offline   Reply With Quote
Old 01-06-2025, 06:32 PM   #2
Zeke3
Zeke3's Avatar
Default Re: 37 transmission question
The transmission comes up and out on the 1937. Detach the front seat and move it rearward to give yourself room to work. Why don’t you want to remove the rear mount? Disconnect the rear mounts and the rear support comes out with the transmission. You will have to move the rear axle rearward to disconnect it from the u-joint.
Zeke3 is offline   Reply With Quote
Old 01-06-2025, 07:33 PM   #3
oswego37
Zeke, thanks for the response. I did not want to remove the rear tranny support ,if I dint have to. your advise is right on. A lot of work to pull a tranny! thanks , Ernie
