Old 01-05-2025, 08:18 AM   #1
De Konjel
De Konjel's Avatar
Default Engine build date
Came across a Ford 4 Banger with engine number B5306196.
What is the build date of this engine?
Checked the fordgarage.com website and then it should be later then 1934??
De Konjel is offline   Reply With Quote
Old 01-05-2025, 10:36 AM   #2
Bob C
Default Re: Engine build date
Is it a diamond block?
Old 01-05-2025, 10:54 AM   #3
De Konjel
De Konjel's Avatar
Sorry I have no idea!
But I think it was a stationairy engine.
Old 01-05-2025, 11:50 AM   #4
cas3
Look for a small raised up diamond cast on the right side, front, near timing cover IIRC
Old 01-05-2025, 03:10 PM   #5
DavidG
DavidG's Avatar
The '33-'34 version of the Model B engine continued to be produced for service and industrial applications until 1941, so number 306196 is well within the realm of possibility given that number 292536 was produced in August, 1934.
Old 01-05-2025, 07:28 PM   #6
mcgarrett
Look on the lower front passenger side of the block down near the oil pan rail and you will see an alphanumeric code cast into the block. Vince Falter's website https://www.fordgarage.com will show you how to decode and know when it was made. I have a "service replacement" diamond block Model A engine made Feb. 27, 1937.
mcgarrett is offline   Reply With Quote
