Old 12-18-2024, 06:47 PM   #1
Will Kimble
Default Need help with a G series 6 cylinder transmission
I am working on a G series 6 cylinder transmission and the case is bad in the thrust area. This is a top loader case - not a side loader. These seem more rare than a LZ transmission! Looking for leads on a replacement case or even a complete transmission for sale.
Thanks,
Will Kimble
Will Kimble is offline   Reply With Quote
Old 12-18-2024, 07:45 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Need help with a G series 6 cylinder transmission
The G-series 6 used the same basic transmission as the V8 but gearing may have been different. The top shift case for the light duty pickups from 1937 though at least 1951 are all compatible. The G engine had it's own half bell that is unique to that block. The 9N and V8 60 transmissions were the odd balls in that time frame. The-78 case could be used with early or late gears. That casting number is on the lower rear part of the casting.
Old 12-19-2024, 12:15 AM   #3
cas3
I agree with Rotorwrench, the bolt pattern on the back side of the 6cyl half bell is the same as v8's back to 32. Should be easy to find a 78 case...37 and up I believe
Old 12-19-2024, 06:29 AM   #4
Mac VP
Mac VP's Avatar
Sadly this does not apply here…..the G series Six has a different starter bendix location than the V8 so the usual 78 series case would not work. I will try to upload a picture of one today. Here it is:
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 12-20-2024, 01:00 PM   #5
rotorwrench
I've not seen many G-series so no surprise being wrong on that one. The G series of engines ran from 1941 through 1947 when the H-series came on line. They were used in cars and lighter trucks in that time frame. Ford made a lot of them for the war-time but they had a differnt transmission in the G8T trucks. Look for an old ragged out jail bar pickup or keep scouring the flea-pay and other sites.
Sorry to get the OP's hopes up but they are still out there. Maybe someone else knows of one.
A good machinist may be able to repair an old one with wear on the back inner thrust face. It could be brazed up and machined with a special counter bore but it might be expensive.
Old 12-20-2024, 01:44 PM   #6
rockfla
rockfla's Avatar
Rotorwrench
FYI, Will is Mac VanPelts right hand man, SO he, in affect, is like E F Hutton when it comes to transmissions for the V8 era.....when he talks he knows of what he speaks!!!! YOU are spot on with the "military" crowd....WILL, IF you read this you might try the MVPA and see IF they have a SWAP meet area, "maybe" one out of a GTB or a Greyhound (I think Ford did a greyhound?), I don;t believe the T16 ever used a 6, only the V8 SO......?? OR any WWII surplus sites/vendors.
