Old 12-16-2024, 02:48 PM   #1
rockfla
rockfla's Avatar
Default Wiring question
For the very basic purpose of running an engine on an engine run stand, can I just run a "hot" wire to the left of the ballast resistor and the red wire from the right lug of the ballast resistor to the coil and be done with a basic on off toggle switch on the "hot" lead???? Again, just to test run it, heat cycle it and check it for leaks.
Old 12-16-2024, 02:54 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Wiring question
Yes. The fuse is only used for the lights.
Alan
Old 12-16-2024, 03:59 PM   #3
rockfla
rockfla's Avatar
Thanks for the confirmation
Old 12-18-2024, 07:27 AM   #4
Terry,OH
Terry,OH's Avatar
How are you going to turn the motor off without a switch in the coil circuit?
Old 12-18-2024, 07:56 AM   #5
rockfla
rockfla's Avatar
TerryOH
NOTE (In my very first post): "For the very basic purpose of running an engine on an engine run stand, can I just run a "hot" wire to the left of the ballast resistor and the red wire from the right lug of the ballast resistor to the coil and be done with a basic on off toggle switch on the "hot" lead????" Does this not take care of that issue?? OR do I need the more "advanced" set up
Old 12-18-2024, 09:05 AM   #6
pistonbroke
As far as the ignition goes , thats perfect. Tim
pistonbroke is offline   Reply With Quote
Old 12-18-2024, 10:13 AM   #7
rockfla
rockfla's Avatar
thanks Tim, I "thought" I had it covered BUT TerryOh had me second guessing.....Terry is one of the ones I consider "E F Hutton"....when he speaks you listen!!!!!
Old 12-19-2024, 08:40 AM   #8
Terry,OH
Terry,OH's Avatar
Running the wire and power to the resistor and coil is fine to get it started, if the battery is grounded to the frame of the stand but power has to be removed to stop the engine from running. Short of ripping one of the wires off a running engine a switch to open the ignition circuit is prefered. Plus if the engine stalls for any reason the coil need to be de-energized so it does not overheat. You don't have to use an original starter switch, a wall light switch works well.
