Old 12-15-2024, 01:58 PM   #1
rawlir
Default 46/47 Dash panel gauges
I have Period Correct USED gauges (oil pressure, amp, fuel) Is there a way to check them prior to installation?
rawlir is offline   Reply With Quote
Old 12-15-2024, 04:28 PM   #2
FortyNiner
FortyNiner's Avatar
Default Re: 46/47 Dash panel gauges
Do you want to fully test them or just check for movement?
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 12-16-2024, 10:17 AM   #3
rawlir
I would like to fully test them....
Old 12-17-2024, 02:27 PM   #4
FortyNiner
FortyNiner's Avatar
You'll need a 6v power source. I tested my fuel gauge by simply wiring the sender, gauge, and power with the sender out of the tank. Moving the sender arm should move the gauge. The amp meter can also just be wired up before installation to check it.
I'm not smart enough to know about oil pressure gauge testing.
Old 12-17-2024, 02:54 PM   #5
tubman
tubman's Avatar
I'd try my air compressor, an adjustable regulator, and some brass fittings.
Old 12-17-2024, 03:03 PM   #6
GB SISSON
GB SISSON's Avatar
I came up from the shop for lunch, read this thread and went down and put some junk together while Denny was typing.
GB SISSON is online now   Reply With Quote
Old 12-17-2024, 03:15 PM   #7
tubman
tubman's Avatar
Even better. The pressure source is genius. If your tire gauge is any good, you can even check for accuracy.
Old 12-17-2024, 03:23 PM   #8
GB SISSON
GB SISSON's Avatar
Just don't ask how I check the temp gauge (at 98.6) Back down to the shop after that one...
Old 12-17-2024, 08:02 PM   #9
GB SISSON
GB SISSON's Avatar
OK, so I know it's kinda gross thinking about holding that brass sending unit under my tongue like having your temperature taken at the doctor's office.... Heck, it'd have to be in there for at least ten minutes and I don't think I could go that long without talking! Where's the 'roll eyes' imogee anyhow? What?
