#1 |
I'm tearing down an 8ba block in preparation for a trip to the machine shop, going to see if it's good or a boat anchor. Anyhow, I need to remove the oil pump idler gear, I threaded a bolt into the gear and gave some tugs with my rather small slide hammer..... didn't budge. Just want to verify this is the correct method for removal? Thanks.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
#2 |
Best I can remember, it should slide off the shaft using a couple of screwdrivers as levers. While you're at it, check the bushing to make sure it's not worn allowing the gear to rock back and forth on the shaft.
#3 |
Correction to my previous post. I seem to remember now that I had to use a larger slide hammer to remove the gear shaft. Apologize for the misinformation.
#4 |
Here's an earlier helpful thread about this gear.
https://www.fordbarn.com/forum/showt...ump+idler+gear |
#5 | |
I have to thank you, and laugh at myself with you directing me to a thread of MY OWN from 2 years ago when I was facing the installation of said gear. Guess that shows the extent of my memory. Well I need to find a BIG socket or heavier slide hammer. Thanks!
#6 |
#7 |
Definitely a case of "CRS" - LOL
#8 |
Dale, is that 'Can't Remember Syndrome'?
#9 |
Close . . . it usually means "Can't Remember Shxt"
#10 |
To remove that gear I use my KR Wilson tool.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
#11 |
Also a milder version of CRAFT Can't remember a frik'n thing
Making the simple complicated for over 30 years. |
#12 |
Thanks guys, I'll have to remember those acronyms.... Wish me luck.
#13 | |
Ya, I've looked all over and can't find mine.
#14 |
Simple solution. Buy a new one. The one you already have will appear almost immediately
https://www.nirgv8.org |
#15 |
Works every time for me. I shouldn't complain at this point in my life BUTT, was under the 49 doing yearly. Needed a wrench, got out from under, went to toolbox AND WONDERED WHY I WAS THERE... Jeez
#16 |
Reminds me of my last few years working on fork lift trucks. Working on a truck at my stall with my tools directly behind me, I would turn around to get the needed tool and forget what I was after. I would stand and look into the tool cabinet trying to remember what I was doing to the truck. Many times I had to turn around and see what I was doing to determine which tool I was after. This malady was going on 20 years ago so you can only imagine what I deal with now! LOL NRTF (not really that funny)
#17 |
The Wilson tool is just a stout cylinder with a bolt to pull that gear. You could probably rig up something with a bar, some spacers, and a bolt to pull it. It’s just pressed in.
#18 |
Have to dig it up, but I made one using part of a Model T running board brace. Worked well.
I dig coal, which provides motivation for EVs. |
#19 |
Well guys, I took this block to the machine shop for hot tank, bake and mag, and decided to "delegate" a couple additional tasks: remove the front oil gallery plug and the idler gear. I have done both before, but this time around I'm going to let someone else have the fun.
