Old 12-14-2024, 05:25 PM   #1
Bullerman
Default Flywheel
what companies sell a flywheel for the 239cu in Flathead. I see th at Speedway. Anybody else.
Bullerman is offline   Reply With Quote
Old 12-14-2024, 05:37 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Flywheel
There's some on Ebay but, where ever you buy, make sure you have the correct tooth count. I sent you a PM.
Old 12-14-2024, 07:03 PM   #3
rotorwrench
rotorwrench's Avatar
Since 239 CI engines came out in 1939, there are two different types. The pre-8BA and the 8BA types. The starter ring mounting is different between the two so just be aware of which type is needed. I've seen the aluminum types with the steel insert so there is that difference as well.
Old 12-15-2024, 10:48 PM   #4
3twinridges
3twinridges's Avatar
Centerforce makes an 8BA flywheel and diaphragm pressure plate.
3twinridges is offline   Reply With Quote
Old 12-16-2024, 12:34 AM   #5
Shoebox
Shoebox's Avatar
..... and they are a thing of beauty!
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
