Old 12-02-2024, 06:54 AM   #1
Bob56
Bob56's Avatar
Default Testing Fuel Gauge
How would I go about testing this fuel gauge for 1936[ATTACH]Fuel Gauge 2.jpg[/ATTACH]
Bob56 is offline   Reply With Quote
Old 12-02-2024, 07:57 AM   #2
corvette8n
corvette8n's Avatar
Default Re: Testing Fuel Gauge
I think you can use a 1-1/2 volt battery to see if the needle moves., if you have an aftermarket sender in the tank you’ll never get an accurate reading on your gauge.
Old 12-02-2024, 08:09 AM   #3
glennpm
glennpm's Avatar
The electric fuel gauge has a coil that heats up with amperage from the tank sender which also has variable output controlled by arm position which heats a bi-metal strip sending amps to the gauge.
From https://forums.aaca.org/topic/238627...-gauge-repair/
"19tom40 Posted June 30, 2014
A good original type sending unit should read near 0 ohms at all positions of the arm. An ohm meter will read the resistance of the coil wound around the bi-metal strip and the resistance of the contact points. The coil only has a few windings and will have very little resistance. The dash unit has no control over the amount that the needle moves, this is done by the sending unit. As the amount of fuel shown by the dash gauge is just an approximate value, the full current test is accurate in determining if the gauge is functional.
Here is a photo of the inside of an original type fuel sending unit. The gap in the contact points is controlled by the position of the float arm. If you do not have an original type available to you, remove the tank unit and connect it to the gauge with a jumper wire. Measure the depth of the tank and bend the arm on the sending unit to travel that distance. I like to have about 1.5" straight section near the part that moves the resister slider and then a 90 degree bend that is adjusted for the depth of the tank. Check to see that it reads full near the top and empty near the bottom. I don't have a photo of one at this time.
Koates may chip in here.
Glenn
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 12-02-2024, 08:39 AM   #4
glennpm
glennpm's Avatar
If it was me, I'd put a AA battery temporarily across the two gauge posts. If the needle moves, it is good.
Glenn
Rumble Seat’s Notes
Old 12-02-2024, 01:10 PM   #5
terry
I have used a 6v lamp battery to test them. But, be careful not to keep the circuit on too long or the heating element will burn out. When in the car, the heatinng element is not on constantly, but continually is going on and off. terry
terry is offline   Reply With Quote
Old 12-03-2024, 06:55 AM   #6
Bob56
Bob56's Avatar
Thank you
Old 12-07-2024, 12:28 PM   #7
Drbrown
Drbrown's Avatar
If you get the system working but your dash gauge is working but inaccurate, there is a way to adjust the dash gauge to accurately show the tanks contents. It involves adding measured amounts of gas to the tank. Then dropping the dash gauge itself down "live" to access its interior and adjust it's settings. I've done all my dash gauges in that manner. I may have posted the instructions here long ago or you can PM me.
Drbrown is offline   Reply With Quote
Old 01-18-2026, 11:06 AM   #8
Skyking227
Dr Brown
Could you send me your testing instructions for gas gauge.
I set up test bench with nos gauge and a used float all King Sealy, I believe.
Using a 12 v battery, switch and single voltage reducer12 to 6v, checking voltage, gauge started smoking.gauge was at full swing.
Everything was grounded, can’t see my problem.
Regards
Skyking
Skyking227 is offline   Reply With Quote
Old 01-18-2026, 11:51 AM   #9
glennpm
glennpm's Avatar
Originally Posted by Skyking227 View Post
Dr Brown
Regards
Skyking
Please re-read the rest of the posts within this thread. Instructions have already been provided. Testing should be a quick intermittent application of voltage with a AA or AAA battery otherwise you may burn it out.
Rumble Seat’s Notes
Old 01-18-2026, 01:53 PM   #10
hueyhoolihan
FYI...
i discovered that the some of the dashboard gauge wiring on my '41 involved conductive plates. my research showed, and empirical evidence also showed, that wires with sufficient gauge to effectively dissipate heat (i.e. thick enough) and with the flexibility (thin enough) to do the job don't exist. in that if they are not thick enough heat will melt the insulation, and if not thin and flexible enough it's next to impossible to manipulate them into position. so much so that Ford decided that plates were necessary to do the job. in particular between the fuel gauge and the oil pressure gauge.
hueyhoolihan is offline   Reply With Quote
Old 01-18-2026, 02:54 PM   #11
glennpm
glennpm's Avatar
Originally Posted by hueyhoolihan View Post
FYI...
There are good options now. I found out about multi (gazillion) strand wire for RC cars, etc. My 2007 Buell had a wiring design issue. A main ground termination, with a cold fused joint, was near the end of a run right through the headstock, an obvious fatigue from bending flaw. Someone in the group mentioned it. I bought some then and then a bunch later for an '87 XS650 project.
https://www.acerracing.com/collections/superworm-wire :-)
For larger gauges, use welding cable which is also very flexible using multi strands and slippery inner casing.
Rumble Seat’s Notes
Old 01-18-2026, 04:12 PM   #12
ford38v8
ford38v8's Avatar
… wires with sufficient gauge to effectively dissipate heat (i.e. thick enough) …
Huey, I’m thinking this is foggy thinking…. Heat is related to resistance, so a heavier gauge wire having negligible resistance produces no heat.
Alan
Old 01-19-2026, 07:08 AM   #13
deuce lover
deuce lover's Avatar
What glennpm said in post #4. I have worked on these gauges for yrs and use a 9V smoke detector batt with alligator clips attached to wires .That hold them secure to the batt terminals.I just touch those wire momentarily to the gauge lugs.If needle moves the gauge is good - to me.I reverse polarity if no movement .If still no movement I open up the gauge and do surgery.Most times that heating element wire is severed.Sometimes I am able to do a repair and sometimes not.
deuce lover is offline   Reply With Quote
