#1 |
I found this girl in storage. It had been stored 30+ years.
Through the knowledgebase here and some YouTube videos, I was able to get it running. It had a signifigant leak at the water pump. More knowledge gathering I learned how the waterpump worked. Previous owner had filled the whole cavity with grease. I literally had to scope it out with a spoon. I also found there was no packing. While working with it I discovered about a 1/4" movement in the shaft, back and forth. Some have mentioned there may be some movement, but I thought this was a lot. I tried to attach a video, but too new to the forum. Last edited by mattgic; 02-17-2025 at 08:26 AM. |
#2 | |
Nice barn find! Should be a lot of fun to work on. I love the fender-mount turn signals.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#3 | |
The Master Cylinder Enjoying life at the beach in SoCal... |
#4 |
Looks like it might clean up pretty well. As per above answer, yes, there's probably wear inside the cylinder head on the boss that the end of the water pump shaft rides on. Only my opinion, but I think you are better off with the collar mentioned instead of the longer shaft. The collar can be installed to give you the desired .003" - .005" endplay whereas there's no way to guess at how much wear there is inside the head. If the new, longer shaft is too long, you'll cause other problems with how the water pump fits to the head.
Keep investigating & asking questions. You'll learn a lot along the way. Good Luck. |
#5 |
The shafts for the leak proof water pumps do not back and forth. This may be a good option for you. They do not leak and have sealed bearings. See https://www.snydersantiqueauto.com/p...d=979246&cat=0
#6 |
#7 |
Would the collar be considered a fix or more of a bandaid?
#8 |
Thanks for all the feedback. I love all the unique knowledge on this forum. The car is a '28. She's far from original but full of originality.
#9 |
Some may call it a bandaid but I have had one one my car for ~10 years so I call it a "repair".
#10 |
I drilled and tapped the wear spot in the head and used a bolt
#11 |
#12 |
Not necessarily, only if it is worn through to the water jacket behind it. On the other hand, if the rest of the engine is sound a high compression head can contribute significantly to more power.
#13 | |
#14 |
I have installed 2 collars and they work great. I would consider it a repair.
#15 |
You can also move the impeller for adjustment.
#16 |
mattgic's Ford Model A Town Sports Coupe |
