Old 11-26-2024, 02:44 PM   #1
Big1096
Default 1940 Deluxe fan slipping
Hey all!
I have a 40 coupe with all original running gear. I was trying to turn the engine over by hand the other day and the fan spins on the shaft without turning the motor. I took the fan off the shaft and I don’t see any way to tighten anything there. It just seems to slip inside the housing. My concern is that I’m not getting the RPM out of the fan that I should be at higher engine speeds. Has anyone dealt with this, and is it even a problem? I can’t seem to find any info on it. I can tack weld the fan to the housing, but I’d rather not if it’s designed a certain way.
Thanks for any guidance!
Jim
Big1096 is offline   Reply With Quote
Old 11-26-2024, 04:30 PM   #2
69a
Default Re: 1940 Deluxe fan slipping
Deleted
Last edited by 69a; 11-26-2024 at 05:59 PM. Reason: I wrongly thought it was a belt driven fan.
69a is offline   Reply With Quote
Old 11-26-2024, 04:34 PM   #3
Big1096
Originally Posted by 69a View Post
The fan is supposed to spin on the shaft. If you want to turn the engine over by hand, you should really do it at the crankshaft pulley. With either a crank handle or a socket on the crankshaft pulley bolt. Make sure the ignition is off.
Ok great, thanks. That was my bigger concern, that the fan was slipping on the shaft and shouldn’t.
Old 11-26-2024, 04:56 PM   #4
kurt v
on orig 40 motor the fan is mounted solid to the crank, the later motors are belt driven you could turn that fan
kurt v is offline   Reply With Quote
Old 11-26-2024, 05:38 PM   #5
42merc
42merc's Avatar
The '40 crank mounted fan has molded rubber connecting the blade to the hub. I suspect the bond has deteriorated and allows the fan to turn without turning the hub.
42merc is offline   Reply With Quote
Old 11-26-2024, 05:41 PM   #6
Kube
Super Moderator
Kube's Avatar
Originally Posted by Big1096 View Post
Hey all!
Jim
Jim, If I understand you correctly, the fan blades are turning but the fan shaft is not. Correct?
There is a rubber dampener between the blade assembly and hub. If it is so loose you can turn the blades, I'd be looking for a replacement fan. You should be able to turn the crankshaft by the fan. Not the best thing to do, but it can be done and has been zillions of times.
