Old 11-25-2024, 08:39 PM   #1
Gene1949
Gene1949's Avatar
Default Time to change and flush green antifreeze
Stuck the voltmeter in the radiators of the 49 Ford, 69 Camaro and 97 Jeep. All showing 275-350 millivolts. Before I research I thought I would ask the wiser heads here.
Two questions.
(1) What are you guys using?
(2) Since I live in the desert south-west I was going to dilute for a temperature of 0 to 5 above. Will that provide me with the necessary anti-corrosion?
Gene1949 is offline   Reply With Quote
Old 11-27-2024, 09:11 AM   #2
corvette8n
corvette8n's Avatar
Default Re: Time to change and flush green antifreeze
https://www.napaonline.com/en/p/ZRXZXC04
Has anti-rust additives.
