#1 |
Screwless window garnish mounding. How do the clips work? I have new clips but if in install them the moulding won’t button hook in. Withe the clips off I put the top in first then bottom will go in. I did not take apart so I have no idea where the five clips go. Any help will be appreciated.
Carl
#2 |
1939 Ford Sedan Delivery |
#3 |
could you show a pic of the clips? The ones i bought for my 36 were ever so slightly different and I had to go with the old ones. terry
#4 |
C0442049-2575-4E66-B5C1-F74E10145B2C.jpg 547AD0F5-4A37-4DF6-82B5-4EEC88B3FA71.jpg Old and new clips Thanks Terry Last edited by Vette1345; 11-25-2024 at 09:56 AM. |
#5 |
Entirely different from mine. Sorry, but I can't help. Hope someone will come on that
can help you out. terry |
#6 |
#7 |
I'm sorry I don't have any input, I took mine off and back on but don't recall how they attached. Shouldn't be specific to sedan delivery ...In any case. Can you post some photos of your 39? I have one also, they're fairly rare so nice to see others..
-WANTED-
CYLINDER HEADS 77-6050B, 81AS - 81SB - 99AS - 99SB - 19AS |
#8 |
Did they make a DeLuxe sedan delivery in '39? That would be pretty much my ideal vehicle.
#9 |
I just recently found out they made a hand full of 38 "standard" Sedan Deliveries. I'm gonna stick my neck out and say NO to a 39 Deluxe sedan Delivery, the closest to that grill style, I think, would be a 41 Sedan Delivery NO??.....I would have said no about a 38 standard too......SO hell, what do I know?
#10 |
#11 | |
I could be wrong but I believe in 37\8 they did actually offer a "deluxe" sedan delivery but the 38 still features the standard type sheet metal. Just upgraded with a chrome windshield frame and maybe a few other options. As far as I'm aware the 39 did not have this option. 39 was a pretty low production year with only around 3000 produced.
-WANTED-
#12 | |
Looks like a fairly solid vehicle from that angle. Good luck getting it together. If you need any photos or anything, mine is mostly as it was parked in 1948.
-WANTED-
#13 |
I got it out of Ca. but still had to replace all the floors. The rest of it had spot rust that I cut out for new metal. I am resto moving it keeping 98% original but will have all modern running gear underneath. I copied the pictured back interior you posted. I had just built all new panels out of 1/8 in. abs plastic. Mine was gutted when I got it. All the panels are ar the upholster now.
Carl |
