Old 11-14-2024, 07:58 AM   #1
FrankWest
FrankWest's Avatar
Default simplest fuel filter to install
What is the simpliest and easiest fuel filter to install on my 1933 model B ford?
FrankWest is offline   Reply With Quote
Old 11-14-2024, 08:33 AM   #2
FrankWest
FrankWest's Avatar
Default Re:NO need for fuel filter because of fuel pump
On the 1933/34 model B does the fuel pump also serve as a fuel filter or should I install and addition fuel filter.
Old 11-14-2024, 08:44 AM   #3
rockfla
rockfla's Avatar
Default Re: simplest fuel filter to install
As KirkNJ posted in your "other" post, IF you have the "original" fuel pump, when you take the acorn nut off and remove the cap, there "Should" be a fine mesh screen inside the pump bowl, toward the upper half of the pump. That screen is the only means of "filtering" in the "original" fuel supply system. SO in essence, your pump is both a pump & filter all in one!!!
Old 11-14-2024, 08:53 AM   #4
Tim Ayers
Judging by Frank's other posts, enough gunk is getting past the fuel pump screen and clogging the jet of the carb.
Old 11-14-2024, 09:34 AM   #5
Jack E/NJ
Jack E/NJ's Avatar
Simplest & safest is probably an inline metal can filter mounted on suction side of pump. Usually includes hoses and clamps for 1/4", 5/16" or 3/8" tubing.
Jack E/NJ is offline   Reply With Quote
Old 11-14-2024, 10:27 AM   #6
19Fordy
19Fordy's Avatar
I have used two see through filters for past 20 years. Made my own end caps to fit the AN fittings. Also, have another one under the car between tank and electric fuel pump. Have had no leaks or "glass" problems. Install so it won't "bang" into something or touch another component.
https://www.aliexpress.us/item/32568...Cquery_from%3A
and
https://www.aliexpress.us/item/22518...Cquery_from%3A
More to choose from here:
https://www.amazon.com/s?k=see+throu...l_9cz2ef2urz_e
Old 11-14-2024, 10:48 AM   #7
51504bat
51504bat's Avatar
Don't use one of these. Don't ask me how I know.
Old 11-14-2024, 11:33 AM   #8
KiWinUS
KiWinUS's Avatar
I have had one like this on a vehicle for over 25 years and no issues.
Old 11-14-2024, 04:17 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
Get a Racor filter for boats— it has a giant sediment bowl with a drain
Old 11-14-2024, 04:40 PM   #10
ford38v8
ford38v8's Avatar
I also have heard horror stories about this particular filter. You’ll hear success stories also, so I suppose it’s a handsome way to die, right?
Alan
Old 11-14-2024, 07:24 PM   #11
tubman
tubman's Avatar
One thing to remember : while your '32 Ford didn't come with a real filter when it was new, it also didn't come with a 90 year old fuel tank and line.
Old 11-14-2024, 09:12 PM   #12
51504bat
51504bat's Avatar
Had 2 Wix brand filters. One near the electric fuel pump by the tank and one between the fuel pump and carb. Both leaked where they threaded together. Luckily I found the leaks before they caused a fire. I initially installed them because the filter element was replaceable and you could see if there was contaminants in the glass housing. Just my experience but never again.
Old 11-14-2024, 11:44 PM   #13
cas3
I had one of those glass filters on my model A. The screen is too coarse, stops big chunks, but a couple times every summer I would clean the carb bowl and find very fine silt in the bottom. Yeah, I know...tank should be cleaned but I drive the heck out of my cars and cleaning the filter is easy. Switched to a clear plastic one so I can see whats going on, with paper element inside, much better results. Frank, as I explained before, its easy, save your original line, make up a new one for the filter just to see whats happening. Easy peasy, couple fittings...some hose...two clamps
Old 11-15-2024, 03:47 AM   #14
19Fordy
19Fordy's Avatar
Me too.
Old 11-15-2024, 03:48 AM   #15
19Fordy
19Fordy's Avatar
I know you said "don't ask" but, did the glass filter leak or break?
Old 11-15-2024, 06:02 AM   #16
deuce lover
deuce lover's Avatar
Amen to that!
If junk in the tank the fuel filter will not solve the problem -it will just keep getting plugged.Suggest dropping the fuel tank and inspecting it and clean it out.Quite a job if you have never done that.Impossible to do that when its in the car. Then while you're at it clean the sender and blow out the fuel line ( with it disconnected from the carb).
deuce lover is offline   Reply With Quote
Old 11-15-2024, 10:32 AM   #17
Planojc
Planojc's Avatar
Same here, on three cars.
Planojc is offline   Reply With Quote
Old 11-15-2024, 10:50 AM   #18
51504bat
51504bat's Avatar
Leaked where the ends screwed on to allow the filter to be changed
Old 11-15-2024, 10:58 AM   #19
19Fordy
19Fordy's Avatar
THANK YOU for letting us know. I think those end caps are made of die cast zinc. I never had any problems like you mentioned but replaced the original end caps with my own made out of 6061 aluminum because I wanted the look of aluminum. Use a drop of oil on threads when assembling. I realize most folks will be using the filter "as is" without custom made end caps so your experience is worth knowing.
Old 11-15-2024, 11:06 AM   #20
cas3
My glass one had a plastic screen, not a paper element. If there is a better element, that would be good. Mine never leaked, and I liked that you can easily take it apart for cleaning.
