Old 11-13-2024, 09:31 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default 53 Mercury P/S add-on
How feasible is it to upgrade a 53 stock Mercury to power steering? Parts availability? Thanks all.
Tim Carlig
dean333 is offline   Reply With Quote
Old 11-14-2024, 02:47 PM   #2
51shoeboxer
Default Re: 53 Mercury P/S add-on
There is a complete kit available on ebay right now. Item number 226448298660. I am not affiliated with ebay or the seller; just providing information.
51shoeboxer is offline   Reply With Quote
Old 11-14-2024, 07:08 PM   #3
pistonbroke
In 53 powersteering was an option. I didn't know until I saw one at the Portland swap a few years back. I like a stock bolt on over a aftermarket job any day. Tim
pistonbroke is offline   Reply With Quote
Old 11-14-2024, 08:25 PM   #4
tubman
tubman's Avatar
$3200? Ouch!
Old 11-14-2024, 09:16 PM   #5
tubman
tubman's Avatar
Thinking completely outside of the box here. I have a '67 Corvette with power steering. There is nothing in the steering box itself that has anything to do with the power assist. After getting the pump mounted on the engine, everything else is external and should bolt on. All parts are readily available and priced reasonably.
Here's what it looks like :
Old 11-14-2024, 10:03 PM   #6
dean333
dean333's Avatar
I think electric gotta be the way to go.
Tim Carlig
Old 11-14-2024, 10:11 PM   #7
tubman
tubman's Avatar
Compare the pictures of the eBay '53 Ford setup and the Corvette unit. They appear to work on the same principle. The cars are of similar size and weight. The hard part would be the drive pulley. It would probably be easiest if the Corvette center link is close enough to be adapted to the Ford. Too bad I'm halfway to Florida or I'd be taking pictures and measuring parts.
Old 11-15-2024, 11:03 AM   #8
Merc Cruzer
Merc Cruzer's Avatar
https://www.ebay.com/itm/22644829866...Bk9SR9qnxojmZA
Depending what the unit actually came off of, you might still have to swap out the end plate, that is attached to the passenger side frame. They were different between Fords and Mercury's. The one in the pictures appears to be for a Ford. It does appear to be complete otherwise. The price is outrageous, but you are lucky to see a complete system come up every 5 years, or more, these days. It took me 3 years to find mine.
I have the same (factory original), unit on my 53' Merc and love it. It has been on my car for over 10 years now, and still works great.
Merc Cruzer is offline   Reply With Quote
Old 11-15-2024, 10:43 PM   #9
kiwi nz
kiwi nz's Avatar
I had a 1968 Fairmont with the same style power steer as tubman shows. I imagine it would be easy to retro fit to a 1953 Ford/Mercury.
I do remember that it did not have the same "road feel" as some of the power steer cars that I have had since.
It was over 45yrs ago now but I do recall "swapping ends" in a spectacular fashion one day, coming out of a corner/intersection in the wet, due to over correction (think multiples).
Lack of steering feedback I seem to remember.
Even though I may still consider such a system for my 54 Victoria, I drive differently now.
Geoff
kiwi nz is offline   Reply With Quote
Old 11-15-2024, 11:25 PM   #10
rjlester
I converted my 54 Meteor (Canadian Ford) to factory PS last winter. I had purchased a parts car with PS and removed everything and restored/painted it all. Bought a new Ram from Rockauto. It is a great system and to this day is not leaking a drop. I put over 2500kms on that car over the summer, no issues with the power steering.
No regrets whatsoever and since I did the work myself I learned a lot.
rjlester is offline   Reply With Quote
Old 11-20-2024, 12:08 PM   #11
Merc Cruzer
FYI, the Power Steering on ebay sold for $2,800. So the next time someone asks you, what the cost of an original 53' PS system is, you will know.
Old 11-20-2024, 03:50 PM   #12
TJ
TJ's Avatar
Not only are those units hard to find and now expensive, many times the ram unit needs to be rebuilt. that is not cheap either.
Old 11-20-2024, 04:44 PM   #13
rjlester
I bought a new RAM from rockauto a year ago, and it works great: https://www.rockauto.com/en/catalog/...+cylinder,7372
Old 11-20-2024, 04:49 PM   #14
rjlester
I never did look at that listing. What was included? What condition was this power steering setup? Was it all rebuilt, or did it still need a rebuild? Control valve seals/ram etc.
Old 11-20-2024, 08:04 PM   #15
pistonbroke
These systems are easy to rebuild as long as the cylinder and shaft are not rusty . ford used them from 53 thru 69 on various cars and trucks they work well and are adaptable . The drag link and control valve are the hard part to find or convert for a custom application. I have rebuilt several over the years with 99% success. The one that faild had a hairline crackthat I missed so it leaked. Tim
Old 11-21-2024, 10:01 AM   #16
Merc Cruzer
Go back up to post #8 and click on the ebay listing, at the top of the post, then scroll down.
Old 11-21-2024, 10:07 AM   #17
Merc Cruzer
My biggest concern is the end plate that mounts to the passenger side of the frame. The system is the same, except for the end plate, used for Ford and Mercury. That part is harder to find, than the entire system, if you are looking for it.
The first one is for Ford and the second one is for Mercury.
Old 11-22-2024, 12:25 AM   #18
rjlester
Ok, I got the link to work this time. Holy smokes, I am surprised at that amount of money. Looks like he just cleaned everything up, couple cans of paint and listed it for sale. I need to grab more of these cars there is crazy money to be made lol
Old 11-22-2024, 08:48 AM   #19
Merc Cruzer
If who ever bought it gets lucky, the pump will work and the ram won't leak too badly. But I can guarantee, that the valve body will need new seals. All I can say is, i am glad i restored my car 12 years ago, and not today.
Old 11-22-2024, 01:48 PM   #20
highbeams
highbeams's Avatar
So many sage replies here. You're surely on your way!
highbeams is offline   Reply With Quote
