Old 11-13-2024, 12:27 PM   #1
FrankWest
FrankWest's Avatar
Default 1933 model b fuel pump cleanout
How do I clean check and clean out my model b fuel pump for sediment?
FrankWest is offline   Reply With Quote
Old 11-13-2024, 12:31 PM   #2
rockfla
rockfla's Avatar
Default Re: 1933 model b fuel pump cleanout
You "should" be able to take the acorn nut off the top of the pump and see inside the bowl.....IF you have the "original" pump. Loosening the drain cock just under the inlet line will allow you to drain the fuel. Pretty simple and straight forward.
