Old 11-13-2024, 11:52 AM   #1
FrankWest
FrankWest's Avatar
Default fuel filter for model B ford
Do you recommend a fuel filter for use on a model B ford or can I just try to keep the fuel pump , sump, clean?
FrankWest is offline   Reply With Quote
Old 11-13-2024, 12:22 PM   #2
rockfla
rockfla's Avatar
Default Re: fuel filter for model B ford
The obvious answer is...A fuel filter does nothing but "help". As I have noticed with your past post, a "added" fuel filter will only hurt you IF you are concerned about having your car judged at an Early Ford V8 Club concours, and given the carburetor/Intake set up from your previous post, "As Henry Built It" is not your #1 concern. SO sure, IF you drive and enjoy your car, which it seems like you do....An aftermarket fuel filter will do nothing but good!!! I currently am running one on my 39 Mercury
Old 11-13-2024, 01:41 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
There should be a screen in the top of the pump.
Old 11-13-2024, 02:26 PM   #4
Tim Ayers
I think until you figure out where the gunk is coming from, you need a filter. It's a pain to keep taking the carbs & fuel pump apart to clean
