35-40 Ford Western Frame (STOCK) uncut not modified not bent,still has origional XXXX no rust $700.00 This is a very hard frame to find in stock condition.I also have a Complete front End with bones spring,axle, spindles drums you know the rest $350.00 this came off a running car.Also a 2 Door Sedan Western Body Hump Back, no rust in tail section,perfect firewall has the stock floor in it but rusty ,rear portion of floor fairly good
have pass door needs work will need a patch piece (SOMEONE CUT IT OUT) (THERE IS NO RUST IN THIS AREA) on pass side from door to the
wheel well I have an after market one included with Car. Car is located near twin cities Minnesota Call roger 612-636-3496
