Old 11-10-2024, 08:45 PM   #1
deskjet894
Default How to install 8BA in a 1934 Ford?
What do I need to do to install a 8BA into a 1934 Ford plus a t5 transmission?
deskjet894 is offline   Reply With Quote
Old 11-11-2024, 12:47 AM   #2
cas3
Default Re: How to install 8BA in a 1934 Ford?
I would switch the heads, water pumps, distributor all over to 59a style stuff to gain 1 1/2" of clearance at the front so you have room for the original fan and radiator. The details are here if you search.
Old 11-11-2024, 09:44 AM   #3
tubman
tubman's Avatar
Most everything has been covered a lot of times and is standard "Hot Rod" fare. The joker is the T5. The first thing you have to do is determine how you want to handle the rear end. Going to a open drive is almost essential. However, The late, great "V8Coopman" and his pal "Heard" figured out how to do it with a closed driveline. They documented the procedure quite well and it should be easy to find on this forum.
Old 11-11-2024, 11:07 AM   #4
glennpm
glennpm's Avatar
Here's the Link. I miss Coop!
https://www.fordbarn.com/forum/showt...T5+TORQUE+TUBE
Old 11-11-2024, 06:05 PM   #5
19Fordy
19Fordy's Avatar
So true. "Coop" was one of the best- a wealth of knowledge and always willing to share.
A great loss to us all.
Old 11-11-2024, 10:50 PM   #6
19Fordy
19Fordy's Avatar
Re: 8BA in a 34 Ford, check this out for starters.
https://www.bing.com/search?q=instal...ANAB01&PC=HCTS
Old 11-12-2024, 12:11 AM   #7
Ol' Ron
Ol' Ron's Avatar
first find a Merc or truck bellhousing that bolts to the 34 trams mission, A good move would be to use a 37 or later trans, Use a set of 8RT water pmps and make your own front mounts to the frame. Some people use the 34 mounts BUT!!!!!! I'duse an electric fan saves allot of trouble. I never did a 34 but I did do several 36'S
Gramps
Old 11-12-2024, 11:00 AM   #8
itslow
itslow's Avatar
Use the '37-48 style water pumps (plug the bypass hole in the block), crank pulley, camshaft, timing cover, and distributor.
The Jeep T5 housing + torque tube route is expensive and can be tough to source. Since you have to modify the frame regardless of tailhousing, I'd probably just go the S10 route and convert to an open driveline.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
