Old 11-02-2024, 10:24 PM   #1
ClassiqueCar
Default 35 Phaeton - Replace the fuel pickup
Is there an easy way to replace the fuel pickup unit behind the rear seat without cutting the metal away or removing the fuel tank? There's an opening in the floor behind the rear seat, but the pickup unit is too far back to clear the opening.
ClassiqueCar is offline   Reply With Quote
Old 11-05-2024, 02:40 AM   #2
Charlesauer
Default Re: 35 Phaeton - Replace the fuel pickup
Replacing a fuel pickup unit without cutting metal or removing the fuel tank can be tricky, but it's not impossible. Here are a few suggestions:
Check for Access Panels: Sometimes, there are access panels or removable sections in the floor or under the rear seat that can provide better access to the fuel pickup unit.
Use Flexible Tools: Consider using flexible tools like a flexible pick-up tool or a flexible inspection camera to help you reach and manipulate the fuel pickup unit from the opening.
Consult a Professional: If you're unsure or uncomfortable with the process, it might be best to consult a professional mechanic. They might have specialized tools or techniques to perform the replacement without cutting or removing the tank.
Look for DIY Guides: There are many online forums and guides that might have specific advice for your vehicle model. For example, some Ford truck enthusiasts have shared their experiences and methods for replacing fuel pumps without dropping the tank.
Charlesauer is offline   Reply With Quote
Old 11-05-2024, 04:51 AM   #3
deuce lover
deuce lover's Avatar
Are you able to post a pic?
deuce lover is offline   Reply With Quote
Old 11-05-2024, 10:44 AM   #4
Planojc
Planojc's Avatar
On my 35 cabriolet I had to drop the tank. The easiest way to access it would be to enlarge the opening.
Planojc is offline   Reply With Quote
