Old 10-30-2024, 04:04 PM   #1
Mike1291
Mike1291's Avatar
Default Burtz Short Block
It appears that Burtz has come out with a pre-assembled short block:
https://burtzblock.com/products/short-block
https://burtzblock.com/pages/block-k...nd-information
This might be good for someone who doesn't have an approved builder that's close to them. It appears that the only things needed are bolt-on parts and has some popular upgrades (modern valve kit, touring cam) already in it.
Feb '31 Standard Coupe
Member of the Little Rhody Model A Club & MARC
Mike1291 is offline   Reply With Quote
Old 10-30-2024, 04:19 PM   #2
Gene F
Gene F's Avatar
Default Re: Burtz Short Block
Thank goodness!
Gene F is offline   Reply With Quote
Old 10-30-2024, 04:20 PM   #3
Gene F
Gene F's Avatar
Lok at the bottom end of that thing. Does that look great or what!!!!!!!!!!!!!!
Old 10-30-2024, 08:19 PM   #4
JayJay
I got that email as well. Interesting that I could not find who is doing the build. Seems like a pretty straightforward build list, although I confess that I’ve no knowledge of Egge pistons.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 10-30-2024, 09:21 PM   #5
johnneilson
I hope that is a typo
The specs list 4.125 stroke
At std bore that’s 195 cu inches displacement not 200.5
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 10-30-2024, 10:45 PM   #6
The Master Cylinder
The Master Cylinder's Avatar
I received that e-mail also. Does this short block need a special oil pump or do you use your old one?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 10-31-2024, 01:27 AM   #7
Synchro909
Synchro909's Avatar
Maybe a typo. Original was 4.25 but even if Terry had to reduce the stroke by 1/8th inch to get it all in the crank case, I still think it is a long way better than the original. Just MHO.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 10-31-2024, 01:40 AM   #8
Lawrie
Lawrie's Avatar
Its the same as original other wise the standard a pistons etc would not fit.
Lawrie
Lawrie is offline   Reply With Quote
Old 10-31-2024, 06:47 AM   #9
ronn
Egge pistons. __________________they have been around forever
Old 10-31-2024, 09:30 AM   #10
JayJay
Standard oil pump, although many put a pressure-relieved high capacity pump in. Terry has instructions on the Burtz Block website on how to modify an original.
JayJay
Old 10-31-2024, 10:42 AM   #11
1931 flamingo
1931 flamingo's Avatar
I've got a friend who just installed one.
Paul in CT
Old 10-31-2024, 12:05 PM   #12
Cape Codder
Cape Codder's Avatar
1931 Flamingo - AND the rest of the story is ?
I don't care if the "A" Starts BUT sure WANT IT TO STOP!
Cape Codder is offline   Reply With Quote
Old 10-31-2024, 08:00 PM   #13
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
Talking Re: Burtz Short Block
If you don't care if it starts, save your money.
Richard
ANAHEIM,CA
Richard in Anaheim CA is offline   Reply With Quote
Old 11-04-2024, 11:53 PM   #14
SanDiegoSteve
Yes, there was a typo on the specs listed for the Short Block. It is actually: Bore x Stroke (in): 3.875" Bore x 4.250" Stroke. Terry always had it correct, I just needed to correct it on the webpage. Thanks for the heads up!
SanDiegoSteve is offline   Reply With Quote
