Old 10-30-2024, 03:05 PM   #1
mrtexas
mrtexas's Avatar
Default carburetor
what stromberg is this one? On a 36 Ford with stock engine
File Type: jpg 465169857_4088592271419854_1836472839739036090_n.jpg (67.5 KB, 74 views)
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 10-30-2024, 03:17 PM   #2
rockfla
rockfla's Avatar
Default Re: carburetor
Without seeing the whole carburetor, it looks like a Stromberg 97
Old 10-30-2024, 03:48 PM   #3
mrtexas
mrtexas's Avatar
How about this one on my 41 with stock engine?
Old 10-30-2024, 04:04 PM   #4
1952henry
1952henry's Avatar
‘40 is a Holley AA1 (94), should say 91-99 on the bowl. I can’t see the numbers clearly, but the air horn looks correct with the small oval vent above and behind the fuel inlet.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 10-30-2024, 05:27 PM   #5
scicala
scicala's Avatar
'39 thru '41 came originally with the Holley model 91-99.
'42 thru '48 came originally with the Holley model 59 like your's pictured.
Will work fine on '39 thru '48 in my opinion.
Sal
Old 10-30-2024, 05:31 PM   #6
scicala
scicala's Avatar
I agree. Stromberg '97 is what came originally in '36.
In all these years, I'm sure it's possible it could be a 40 or 48.
Not sure of the outside differences other than venturi size and jets/PV sizes.
Sal
Old 10-30-2024, 06:52 PM   #7
1942deluxe
1942deluxe's Avatar
Slight correction, 1942 was a 21-29 Holley. 46-48 was the model 59 Holley.
Old 10-30-2024, 07:09 PM   #8
ford38v8
ford38v8's Avatar
Good catch.
Alan
Old 10-31-2024, 06:16 AM   #9
Terry,OH
Terry,OH's Avatar
1939-41 was the 91-99 as mentioned above the top casting is correct but the center die casting is 59.
Without a complete photo of the side of the Stromberg can not tell if 97, 48, 40 or 81. The original Stromberg for the 36 is a small logo 97 also embossed 67 top and center. The large or small logo 97 is identical to the Stromberg embossed 67 and all three are interchangeable. Ford had their carburetors marked with the prefix of the ford part number 67 because they also rebuilt carburetors and did not want to rebuild carburetors used on other car Mfg.
