Old 10-29-2024, 07:43 AM   #1
rockfla
rockfla's Avatar
Default Electrical question
I have a motor on a wooden cradle that I want to test run before I ship it, does the ballast resister need to be grounded to the motor since that where the ground for the battery will be???
Old 10-29-2024, 08:32 AM   #2
koates
Default Re: Electrical question
NO, NO, that would cause a short circuit to ground. The ballast resistor should never be grounded. It connects in line or in series with the ignition switch power feed to the ignition coil. Have a look at a Ford flathead wiring circuit diagram to see how it is connected. In the car they are mounted on an insulated fiber board on the inside of the firewall on most V8s. Regards Kevin.
koates is offline   Reply With Quote
Old 10-29-2024, 08:42 AM   #3
rockfla
rockfla's Avatar
Kevin
I have the "basic" diagram BUT I wasn't sure about the ballast resistor and being grounded OR Insulated from the firewall?? SO Thank you Sir!!!!
Old 10-29-2024, 11:02 AM   #4
highbeams
highbeams's Avatar
https://www.electrical4u.com/ballast-resistor/
a good site -
highbeams is offline   Reply With Quote
Old 10-29-2024, 11:03 AM   #5
highbeams
highbeams's Avatar
Old 10-29-2024, 11:30 AM   #6
tubman
tubman's Avatar
Since there is no radiator, the test run will of necessity be quite short. Why mess with the resistor at all?
Old 10-29-2024, 11:32 AM   #7
rockfla
rockfla's Avatar
o
A very preliminary photo of the motor, there will be a radiator with a cooling fan attached!!! That's why I "mess" with it!! as well as headers and mufflers
Old 10-30-2024, 11:48 AM   #8
solidaxle
solidaxle's Avatar
I would install a flywheel also before running.
solidaxle is offline   Reply With Quote
Old 10-30-2024, 12:15 PM   #9
rockfla
rockfla's Avatar
Yes Sir, already done!!! As well as starter installed
