#1 |
Can anyone tell me if this bumper is for a 1935 or 1936 sedan delivery? Are they different? It was marked “rear” when I bought it but it doesn’t have a groove in the center which causes me concern.
#2 |
1935-1936 Ford Bumpers - 1936 on the Left - 1935 on the Right |
#3 |
This is a close-up of your Bumper end. I believe that it is 1935. |
#4 |
The 35 sedan delivery used the same bumper as the cars, 36 was the first year for the indented rear bumper for the rear door a la the one in my avatar.
#5 |
[QUOTE=rockfla;2346370]The 35 sedan delivery used the same bumper as the cars, 36 was the first year for the indented rear bumper for the rear door a la the one in my avatar. The one you have pictured the bend doesn’t look right? I have pictures of a bent bumper on my computer I will post in the morning!!
#6 |
Now what is REALLY interesting is Mercman's photos. While the outside has the two stripes, the 1935 has a single wide stripe on the inside where the 1936 has a double stripe. The center between the stripes is more defined and a different shape than the 1936. Is the double inside stripe a somewhat common variation? Early aftermarket? Australian? |
#7 |
1936 Ford Sedan Delivery Rear Bumper |
#8 | |
Most North American 1935-36 bumpers (front and rear) have a significant downward swoop in the center section - yours appears to be pretty straight in that regard. Here's a '35. - |
#9 |
He is talking about a Sedan Delivery rear bumper that does not have a swoop.35,36 commercial front bumpers do not have the swoop. Without having the grooves it could be an offshore ,or maybe Euro application
Pictured in post #7 is a '35 rear bumper. The fold over end is more pronounced on a '36. Here is a pic of a '36 SD rear bumper Last edited by deuce lover; 10-28-2024 at 03:09 AM. |
#10 |
1936 Ford Sedan Delivery rear Bumper - deuce lover |
#11 |
Here’s the rear bumper on my 35 Sedan Delivery, it’s been painted black but will be returning to chrome in the future.
#12 |
The fold over ends resemble a 36 to me.
#13 |
It seems that this Thread is getting complicated? This picture that I added was the rear Bumper on a 1936 Ford Sedan Delivery that I saw at the V8 Nationals at Lake Tahoe back in 2013. Earlier in this Thread, it was stated that the 1935 Ford Sedan Deliveries didn't have this curved style rear Bumper. On that basis, I assumed that this was a genuine 1936 Ford rear Bumper, (as the 1935 Fords didn't have them) but on closer inspection, it appears to be more like the 1935 Bumpers. |
#14 |
Welcome Dion35 to Ford Barn.
I hope that you get lots of enjoyment out of being a Member of Ford Barn. Regards Mercman <>< |
#15 |
As deuce lover has pointed out, the bumper on this 1935 Ford Sedan Delivery (Dion35) appears to be a 1936 Ford rear Bumper |
#16 |
Interesting thread here, I have posted several pictures here.....the first being what I saved as an 1935 ad but the wheels indicate 36....showing a indented rear bumper....The second is of a sedan delivery supposedly from a long garage slumber...interestingly on this one its a "straight" across bumper. After purchasing our 35 sedan delivery, which came with an indented 36 bumper....ALL information I had gathered was that 35's had the same rear bumper as ALL the car line of 35, that 36 was the start of the indented bumper
#17 |
I agree with Karl, the bumper in question looks like someone backed into a pole.
#18 |
[QUOTE=Karl Wescott; Now what is REALLY interesting is Mercman's photos. While the outside has the two stripes, the 1935 has a single wide stripe on the inside where the 1936 has a double stripe. The center between the stripes is more defined and a different shape than the 1936. Is the double inside stripe a somewhat common variation? Early aftermarket? Australian?[/QUOTE]
Karl NOT sure IF you are aware BUT many of the Euro (German in particular) 33's and "UP" had NO accent stripes. It seems to be a mixed bag of what I have both modern pictures and "back in the day" photos. I tend to believe that the "non" striped bumpers were a "local" sourced item as Ford of Germany had such an increasing pressure to use "local" materials and suppliers.....SO I think the striped bumpers were what was able to make it in to the country from the USA when "permitted"!!! |
#19 | |
So regarding the bumper, I just assumed it was correct but maybe not - I hadn’t really considered it. Both my front and rear bumpers have the single wide pressing on the inside - same as your photo of the 1935 bumper on the right next to the 1936 bumper. My Sedan Delivery is right hand drive, Canadian built. Would they have started using the different design earlier, or are Canadian made bumpers different to US bumpers? |
#20 |
For those with a sedan delivery, notice the picture of the bumper mounting bracket. On a sedan delivery the inner arm curves outward at the bumper mounting bolt. On a passenger car that arm curves inward at the mounting bolt.
