Old 10-18-2024, 07:27 PM   #1
wickcopland
wickcopland's Avatar
Default Wondering what it's purpose is?
There is a hole in the thing at the back of the trans that the torque tube attaches to. What is it for and is it positioned correctly?
wickcopland is offline   Reply With Quote
Old 10-18-2024, 08:10 PM   #2
Bill OH
Default Re: Wondering what it's purpose is?
Are there threads in that hole? The part on my Ford is turned 180 degrees and has a right angle grease fitting screwed into it - fitting points to the rear.
Bill OH is offline   Reply With Quote
Old 10-18-2024, 08:32 PM   #3
alchemy
alchemy's Avatar
That’s the inner cone, so no threads in it. The hole just lets the grease migrate through a bit. The outer clamshell has the grease fitting in it. Your pic is missing the outer clamshell.
alchemy is offline   Reply With Quote
Old 10-19-2024, 05:14 AM   #4
deuce lover
deuce lover's Avatar
Here is an illustration and Part name and numbers for reference.Hope this helps.Suggest you move that cone or cap ( part 4513)so it points down and mount the 2 piece clam shell (part 4520) accordingly so the grease zerk lines up with that hole.
deuce lover is offline   Reply With Quote
Old 10-19-2024, 07:17 AM   #5
wickcopland
Thank you guys, that is what I was thinking.
Old 10-19-2024, 08:20 AM   #6
Terry,OH
Terry,OH's Avatar
I believe there are two holes, about 180 degrees apart, for lubricant from the Zerk fitting to enter the U-joint area. As alchemy said above. You may be missing several gaskets in this area. Good idea to lube both the inner cap and the front of the torque tube before assembly.
Old 10-19-2024, 08:48 AM   #7
alchemy
alchemy's Avatar
Doesn’t make any difference if the inner cone’s hole lines up with the outer clamshell, because there is a torquetube in between them with no holes.
Old 10-19-2024, 10:14 AM   #8
19Fordy
19Fordy's Avatar
Here's a few photos that may clarify. You can see the clamshell grease fitting on the bottom clamshell in the 4th photo. Don't forget to install the two special square headed nuts at the bottom of the clamshell. The 2 nuts on the motor mount bolts are the acorn lock nuts on the steering arms.
Old 10-29-2024, 05:41 PM   #9
wickcopland
Thank you guys for the clarification
Wick
