#1 |
The overdrive in my 1949 Ford won't kick down. The engine shuts off when the gas pedal is pressed to the floor, but the overdrive won't disengage. The relay, governor, and solenoid contacts are perfect, and the kickdown switch is new. Everything has worked perfect until very recently. Any suggestions??
