Old 10-17-2024, 09:04 AM   #1
37 truck
Default fuel pump delete
Deleting my stock fuel pump on a 59 block, going with an electric pump. Do I need to plug the fuel pump rod hole over the cam shaft, or is it ok to leave alone?
37 truck is offline   Reply With Quote
Old 10-17-2024, 10:16 AM   #2
hotcoupe
hotcoupe's Avatar
Default Re: fuel pump delete
I eliminated the fuel pump on my '37 1/2 ton by removing the fuel pump push rod, I left the pump in place along with the fuel lines. Looks original, works as it should.
Tom
hotcoupe is offline   Reply With Quote
Old 10-17-2024, 12:31 PM   #3
drolston
drolston's Avatar
As long as the electric fuel pump you choose does not block flow when turned off (most do not), you can leave the stock pump in place and just pump through it. I like the redundancy. If either pump fails, I get home. Pick a pump that does not exceed 3 psi to avoid the possibility of exceeding the ability of the carburetor float valve to shut off fuel to the fuel bowl on the carb
Old 10-17-2024, 01:17 PM   #4
19Fordy
19Fordy's Avatar
This question has been discussed many, many times. Do a SEARCH on fuel pump push rod and info like this appears.
https://www.fordbarn.com/forum/showt...d+block&page=2
Old 10-17-2024, 01:25 PM   #5
Ronnieroadster
Ronnieroadster's Avatar
Hi the answer to your question is Yes. When you remove the fuel pump push rod you need to plug the pushrod hole in the block. Without a fuel pump push rod in the hole there's a rather large leak in the main oil feed system of the engine.
Measure the diameter of the pump push rod then usually what's done find a short bolt with solid shoulder the same diameter. Put that in the push rod hole with some good grade RTV placed just under the head of the bolt that will add additional sealing so no oil leaks out..
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 10-17-2024, 04:55 PM   #6
ndnchf
ndnchf's Avatar
On my '39 motor with electric fuel pump, the pushrod is still in place, but pump is removed. I put a small hose clamp around the rod inside the fuel pump stand. The hose clamp holds the rod in the up position so it doesn't bounce along on the cam, yet maintains the oil pressure. Its a simple solution that works well for me.
ndnchf is offline   Reply With Quote
Old 10-18-2024, 10:48 AM   #7
Ken/Alabama
Ken/Alabama's Avatar
No, On the 59 and earlier engines you will not see any decrease in oil pressure by removing the rod. On the later 8BA you probably would because the bushing has a small hole in it that the earlier engines don’t have.
Ken/Alabama is offline   Reply With Quote
Old 10-18-2024, 10:58 AM   #8
glennpm
glennpm's Avatar
X2 Ken
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 10-18-2024, 02:38 PM   #9
hotcoupe
hotcoupe's Avatar
I agree.
Tom
Old 10-18-2024, 03:44 PM   #10
Ol' Ron
Ol' Ron's Avatar
Yes I plug the hole usually with a tapped plug when building the engine. I never use the stock pump, back in the old days the electric pumps were very repiable, but not now/ My last build i installed a Ford in tank pump in the tank and the fuel gauge worked. I think??
That wasa long time ago??
Gramps
