Old 09-20-2024, 08:49 AM   #1
AnthonyG
AnthonyG's Avatar
Default Thread size for vacuum port on Offy BA 4 barrel-intake under carb mount base?
I have an Offy 4 barrel intake for a BA. The internal thread to provide vacuum via a threaded vacuum adapter port has a thread issue I’d like to clean up via a tap. Anyone know what the size its supposed to be’s?
Nomad
AnthonyG is offline   Reply With Quote
Old 09-20-2024, 04:26 PM   #2
Mart
Mart's Avatar
Default Re: Thread size for vacuum port on Offy BA 4 barrel-intake under carb mount base?
Can you just measure it and see what thread it matches most closely? It's probably NPT but hard to say from here. NPT thread specs are easily found by googling.
Old 09-20-2024, 05:48 PM   #3
19Fordy
19Fordy's Avatar
Anthony; Is the port you are asking about the one in the lower left (1st photo) of this 390 Holley (4160) List 8007 with the rubber cap over it? If so it appears to be pressed in, not threaded. The same is true of the other port for vacuum.
Old 09-21-2024, 12:16 PM   #4
Bored&Stroked
Bored&Stroked's Avatar
My guess is that it would be 1/8" NPT - that is what I've seen on most manifolds. I do NOT have your manifold - so consider this a wild ass guess!
Old 09-21-2024, 01:51 PM   #5
Bob C
I think this is the manifold.
Old 09-21-2024, 03:29 PM   #6
19Fordy
19Fordy's Avatar
Oh my gosh Bob, thanks for posting that photo. Somehow, I misinterpreted the original post. I was way off base.
I have that Holley 4 barrel intake on my 8BA and that fitting is 1/8-27 threads like Bob said.
I use that port (second photo) to operate my vacuum wipers. The short straight fitting that screws into the intake and the 90 degree brass elbow takes a 9/16 wrench. Teflon tape on threads.
Old 10-30-2024, 10:00 AM   #7
AnthonyG
AnthonyG's Avatar
sorry for late replies. computer crashed and took a while to fix. the female threaded vac porrt is on rhew manifold just below the carb mounting surface
Nomad
Old 10-30-2024, 10:08 AM   #8
AnthonyG
AnthonyG's Avatar
https://www.fordbarn.com/forum/attac...8&d=1726944705
Nomad
Old 10-30-2024, 10:13 AM   #9
AnthonyG
AnthonyG's Avatar
Thx 19Fordy
Nomad
Old 02-04-2025, 06:37 PM   #10
AnthonyG
AnthonyG's Avatar
Thx 19fordy! Sorry reply is so late. Old Man back issues make everything I do take 5 times as long. I got a couple of 1/8-27 NPT TAPS & there was enough land towards the bottom of the thread so was able to get threads straitened out. I dipped the threaded vacuum fitting 1/8 27 NPT threads in RTV ( PROBABLY overkill) but no more vacuum leak! &?was able to adjust the idle on the two Holley 94 setup!
Nomad
