Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 09-19-2024, 09:11 PM   #1
fordbruce
Default Weak Spark
Hi !!! I have a 1950 Ford Convertible and I put new points and condenser in it and when I try to start it it has a very weak spark. I bought new points and condenser together at NAPA …. ANY SUGGESTIONS ? Thank You !!!
fordbruce is offline   Reply With Quote
Old 09-20-2024, 12:14 AM   #2
Charlie Stephens
Default Re: Weak Spark
My suggestion is that you place your question here: https://www.fordbarn.com/forum/forumdisplay.php?f=4
The section you posted in is for questions to the editors about the site, it is seldom read or responded to.
Charlie Stephens
Old 09-25-2024, 06:16 PM   #3
Grunt Ironwerks
I have had a lot of bad New condensors. Might try several
Grunt Ironwerks is offline   Reply With Quote
Old 08-11-2025, 07:09 AM   #4
ColeHarry
It sounds like you're dealing with a weak spark issue despite replacing the points and condenser. A few things you might want to check: ensure the gap on the points is set correctly according to the specifications for your 1950 Ford Convertible.
ColeHarry is offline   Reply With Quote
