Old 09-19-2024, 01:22 PM   #1
Keith
Default Toe In
Which direction do do you turn the tie rod to adjust toe-in
Clockwise or Counter Clockwise.
Keith
Keith is offline   Reply With Quote
Old 09-19-2024, 03:01 PM   #2
mngrant
Default Re: Toe In
Keith
Paul Shinn has a good video which covers the procedure. You can find this on YouTube.
mngrant is offline   Reply With Quote
Old 09-19-2024, 06:35 PM   #3
32Ford13
Default Re: Toe In
I love Paul's videos, but there is a way way better method to setting the toe in.
Use these plates. I have and they are much more accurate.
https://www.tmrcustoms.com/products/...alignment-tool
Here is the youtube video from the Main A's on these plates:
https://www.youtube.com/watch?v=MT4H26Vj7n8
32Ford13 is offline   Reply With Quote
Old 09-20-2024, 07:16 AM   #4
Bruce of MN
Bruce of MN's Avatar
Default Re: Toe In
I'll have to measure things to see how tall the vertical leg needs to be. The cost isn't bad vs. a version in Masonite that had compromises.
Bruce of MN is offline   Reply With Quote
Old 09-20-2024, 08:38 AM   #5
Ed in Maine
Default Re: Toe In
Keith, you have asked a good question. The answer is either way! You have to move tie rod to see what is happening. This is because when your car was assembled, you don't know what tie rod ends were placed on the tie rod and how it was mounted in the car. It goes together either way! It is easy to see. Before moving the tie rod, take a measurement, move the tie rod 1/2-1 turn and take another measurement. Did you increase toe-in or decrease it. Adjust as necessary. Ed
Ed in Maine is offline   Reply With Quote
Old 09-20-2024, 09:53 AM   #6
Will N
Will N's Avatar
Default Re: Toe In
It also depends on whether you want to increase or decrease toe-in.
Will N is offline   Reply With Quote
Old 09-20-2024, 10:28 AM   #7
katy
katy's Avatar
Default Re: Toe In
And, which end you're looking at it from.
Old 09-20-2024, 12:56 PM   #8
Keith
Default Re: Toe In
That all makes sense on how it was installed. thanks Keith
Keith
