Old 08-21-2024, 07:12 PM   #1
Bruce in southern OH
Bruce in southern OH's Avatar
Default Who sells a non scrip 91-8286B radiator hose
looking for two lower 8AB radiator hoses ( 91A-8286B ) that are non-scrip radiator hoses. Found several but scrip, Drake wants $40.00 each ! I just want to get two new dependable hoses to get on the road. thanks in advance for your time,
Bruce in southern OH is offline   Reply With Quote
Old 08-21-2024, 07:47 PM   #2
tubman
tubman's Avatar
Default Re: Who sells a non scrip 91-8286B radiator hose
I believe I heard that laquer thinner takes the printing off the hoses quite easily.
Old 08-21-2024, 08:18 PM   #3
Kube
Super Moderator
Kube's Avatar
You had heard correctly. A little thinner on a rag and a little rubbing. A minute later and no more script.
Old 08-21-2024, 10:08 PM   #4
Conrad Rossi
Conrad Rossi's Avatar
Check rock auto or your local auto parts store for a generic hose and then cut it to lenght..
-Conrad
Conrad Rossi is offline   Reply With Quote
Old 08-21-2024, 10:18 PM   #5
Flathead Fever
Flathead Fever's Avatar
I just go to the local parts store and match it up to something I can cut it out of. You'll find something that will work.
Flathead Fever is offline   Reply With Quote
Old 08-21-2024, 11:19 PM   #6
cas3
Napa has them, sorry, no part # for you
Old 08-22-2024, 07:05 AM   #7
Thank you, I did not mind the scrip, I am going to remove the hoses to drain and flush the the system and radiator, also replace the the front brake line.
I was just needing new hoses after 40 years of the current hoses on car I did not think they will/would come off without having to cut off to remove. Will try parts stores to see what they can order. Appreciate Help
Old 08-22-2024, 07:27 AM   #8
deuce lover
deuce lover's Avatar
Midwest Early Ford has them,non Ford Script.$35 pr.
deuce lover is online now   Reply With Quote
