Old 08-19-2024, 09:16 AM   #1
soonersace
Default Dual Master Cylinder upgrade proportion valve question.
As mentioned in another post-my 48 hydraulic brakes went out in my 34 Ford.
It currently has the one cylinder master cylinder which meant all my brakes went out when one went.
I’m thinking about upgrading to the dual master cylinder.
Do I need to put a proportional valve on it or some sort of residual pressure valve for the rear brakes?
I appreciate your responses.
soonersace is offline   Reply With Quote
Old 08-19-2024, 09:37 AM   #2
V8 Bob
V8 Bob's Avatar
Default Re: Dual Master Cylinder upgrade proportion valve question.
Proportioning valves are not needed on vintage drum/drum car systems.
Your early Ford Lockheed drum brakes need residual valves with a dual master upgrade, to replace the (check) valve in the original single master. Residuals can be located behind the tube seats on many drum/drum OE masters, or installed inline with aftermarket 10# valves to each axle.
V8 Bob is offline   Reply With Quote
Old 08-19-2024, 09:57 AM   #3
Krylon32
I done countless customer chassis with drum/drum brakes and no proportioning valve. I do use a 1 inch bore dual MC with built in check valves.
Krylon32 is offline   Reply With Quote
Old 08-19-2024, 10:21 AM   #4
Newc
Newc's Avatar
ditto; I use a drum/drum 61/62 Cadillac master with Ford brakes 39/48. Newc
Old 08-19-2024, 11:19 AM   #5
Bored&Stroked
Bored&Stroked's Avatar
Would you happen to know the part numbers . . . will look into it!
Thanks
B&S
Old 08-19-2024, 11:55 AM   #6
glennpm
glennpm's Avatar
Thanks
B&S
https://www.rockauto.com/en/catalog/...+cylinder,1836
Note that most master cylinders without a external manifold/connection block, that have rear drum or front and rear drum brakes, incorporate the check valves within the master cylinder.
Glenn
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 08-21-2024, 10:19 PM   #7
John R
As far as I know 61 master cylinders, Cadillac or whatever, were single circuit units. 62s were dual circuit.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 08-22-2024, 05:15 AM   #8
glennpm
glennpm's Avatar
That's what I found too John, first year 1962.
Glenn
