Old 08-13-2024, 08:47 AM   #1
fourfords
fourfords's Avatar
Default Boyce Motometer repair
Is there someone who can work on reproduction Boyce Motometers? The fluid has
long since dried up.
Thank yooo!
fourfords is offline   Reply With Quote
Old 08-13-2024, 06:56 PM   #2
mleder
Default Re: Boyce Motometer repair
It's a repro- buy another one. Second and best choice: they are not accurate so as long as it looks good keep the non working one and do yourself a favor and install a temp gauge that really works inside of the car so you really know what is going on with your engine
mleder is offline   Reply With Quote
Old 08-13-2024, 08:08 PM   #3
Gene F
Gene F's Avatar
People have had to take them off, because someone tried to steal it. Usually breaks the neck on the radiator.
If you really want it, just buy a new one from Snyders. Put a spring on the probe so it drips into the water if you want it to read more accurately.
Gene F is offline   Reply With Quote
Old 08-13-2024, 09:48 PM   #4
whirnot
whirnot's Avatar
It is not designed to read the temp of the water, only the temp of hot air, or steam. Adding a spring will make it totally ineffective.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 08-13-2024, 09:53 PM   #5
JayJay
I have a MotoMeter on my '31, and a temperature gauge. The MotoMeter looks good and it's a great conversation piece with the public, but I find the red line in the thermometer of the MotoMeter is so slim that I really can't read it from the driver's seat. So to me it's already ineffective. I rely upon the temp gauge.
And I carry an extra radiator cap in case someone decides they need the MotoMeter more than I do.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 08-13-2024, 11:26 PM   #6
oldspert
oldspert's Avatar
Thank yooo!
Not likely it dried up but only is contained in the bulb potion of the glass tube. Try holding it in hot, not boiling water, and see if the color will expand back into the tube.
However, like has been said, they are not really for temp of the engine, but mostly for looks.
Ed
oldspert is offline   Reply With Quote
Old 08-14-2024, 06:28 AM   #7
ronn
sell the old one for a desk mount and buy a new one as suggested.
Old 08-14-2024, 08:46 PM   #8
fourfords
fourfords's Avatar
Alrighty then! Thanks for the tips!
Old 08-15-2024, 06:12 AM   #9
nkaminar
nkaminar's Avatar
The reproduction motor meters are mostly for decoration. It will only register when your radiator is boiling over.
